USNCenturion Posted March 7, 2021 Share Posted March 7, 2021 I just picked up a pot of Tesseract Glow, and there is quite a separation of pigment; the bottom cm is green while the top liquid is yellow. Any amount of shaking I give can’t break up that green layer. I looked about online and it seems this paint is prone to extreme separation and adding a ball bearing was recommended. My question is what do you folks generally use as an actuator? Do you often put these into citadel paints? Does the metal ball hurt the paint at all? Ryltar Thamior 1 Back to top Link to comment Share on other sites More sharing options...
Stercus Posted March 7, 2021 Share Posted March 7, 2021 If you don’t have a ball bearing you can cut a couple of small bits of sprue and put those in the pot. It doesn’t affect the paint at all, all it does is bash the paint about and help to get it to mix. Gederas and USNCenturion 2 Back to top Link to comment Share on other sites More sharing options...
Gederas Posted March 8, 2021 Share Posted March 8, 2021 Seconding what Stercus said.In addition, stainless steel ball bearings for paint mixing are fine to put in paint pots USNCenturion 1 Back to top Link to comment Share on other sites More sharing options...
