TrawlingCleaner Posted May 28, 2021 Share Posted May 28, 2021 The points values in the MM are from their new codexes, they've released the pdfs so that you're not playing without the codex but with points that make no sense when compared with their current units. For example, the MM will have the points for Rubrics with 2 Wounds, they would make no sense for the CURRENT codex. Super simple, no gaslighting required This could be true- but it isn't what they said in the article. Also, why wouldn't they just leave points as is for now- rather than publishing a separate interim version? Are we reading different articles? "Well, we’ve got a confession to make – the points values featured in the Munitorum Field Manual MkII for the Thousand Sons and Grey Knights are actually incorrect. That’s because their codexes were intended to be out at this point, complete with their fancy new rules and updated points values" The only changes in the points from the "interim" pdf in the article to GK and TS are to the landraiders, Storm raven and storm bolters on vehicles which is more than likely in line with all other codex equivalent changes RWJP and Lord Blacksteel 2 Back to top Link to comment Share on other sites More sharing options...
Captain Coolpants Posted May 28, 2021 Share Posted May 28, 2021 (edited) I just really wish they jacked the cost up for heavy weapons! The landraider price is fine... The issue is just how many cheap weapons can ruin it immediately. Edited May 28, 2021 by Captain Coolpants Lord Raven 19 and MindEraser 2 Back to top Link to comment Share on other sites More sharing options...
Xenith Posted May 28, 2021 Share Posted May 28, 2021 How could logistics be the reason for points changes? So lets break this down. GK and 1KS codexes are due out, lets say in March. They have points values in those books. Those books are not published on time for reasons we all can agree are likely TRUE. So then at the end of May, the MM is published. The points in this book are DIFFERENT from the codexes that were due out earlier and are WRONG. This is incorrect, and you have misread the article. The point costs in MM are the same as the codex, which was delayed, but both are different from the current codex which has 1W marines etc. The MM version will be points costs to reflect new faction abilities, etc, and not appropriate to use with the old codex, which is the current version due to delays. So: Current codex = points for 1W rubrics New codex = points for 2w rubrics MM 21 = Points adjustment for delayed codex with 2w rubrics PDF = Point adjustment for 1W rubrics in 9th ed. Lord Blacksteel, BLACK BLŒ FLY, TrawlingCleaner and 4 others 7 Back to top Link to comment Share on other sites More sharing options...
caladancid Posted May 28, 2021 Share Posted May 28, 2021 How could logistics be the reason for points changes? So lets break this down. GK and 1KS codexes are due out, lets say in March. They have points values in those books. Those books are not published on time for reasons we all can agree are likely TRUE. So then at the end of May, the MM is published. The points in this book are DIFFERENT from the codexes that were due out earlier and are WRONG. This is incorrect, and you have misread the article. The point costs in MM are the same as the codex, which was delayed, but both are different from the current codex which has 1W marines etc. The MM version will be points costs to reflect new faction abilities, etc, and not appropriate to use with the old codex, which is the current version due to delays. So: Current codex = points for 1W rubrics New codex = points for 2w rubrics MM 21 = Points adjustment for delayed codex with 2w rubrics PDF = Point adjustment for 1W rubrics in 9th ed. I think maybe you mean misunderstood instead of misread? Because the things you are saying are things you have interpreted from the article, not things that are in the article. Dudley Nightshade 1 Back to top Link to comment Share on other sites More sharing options...
Umbros Posted May 28, 2021 Share Posted May 28, 2021 No, the Munitorum Manual includes points for all books. Not just changes. The points in it for TS/GK are likely the same as in their codexes, which were due out by now but delayed. Metzombie, AenarIT, Oxydo and 4 others 7 Back to top Link to comment Share on other sites More sharing options...
AenarIT Posted May 28, 2021 Share Posted May 28, 2021 The MFM will probably have new points for Sisters and Orks as well, unlikely to be different from the ones in the new codices. Thy simply print out all the points in the game at a certain moment in time. If they thought this book would've been out when those 4 codices (Sisters, Orks and the last two they announced, GK and TS) were already out, the points are 99% likely to be identical. Link to comment Share on other sites More sharing options...
excelite Posted May 28, 2021 Share Posted May 28, 2021 How could logistics be the reason for points changes? So lets break this down. GK and 1KS codexes are due out, lets say in March. They have points values in those books. Those books are not published on time for reasons we all can agree are likely TRUE. So then at the end of May, the MM is published. The points in this book are DIFFERENT from the codexes that were due out earlier and are WRONG. This is incorrect, and you have misread the article. The point costs in MM are the same as the codex, which was delayed, but both are different from the current codex which has 1W marines etc. The MM version will be points costs to reflect new faction abilities, etc, and not appropriate to use with the old codex, which is the current version due to delays. So: Current codex = points for 1W rubrics New codex = points for 2w rubrics MM 21 = Points adjustment for delayed codex with 2w rubrics PDF = Point adjustment for 1W rubrics in 9th ed. Thx for clearing that up, was a bit confused when I first skimmed over the article, but this makes sense… So basically the pdf is a temporary solution until the codexes drop and then we go straight to the mm points and skip the ones in the codex, in case i understood correctly? TrawlingCleaner 1 Back to top Link to comment Share on other sites More sharing options...
TrawlingCleaner Posted May 28, 2021 Share Posted May 28, 2021 So basically the pdf is a temporary solution until the codexes drop and then we go straight to the mm points and skip the ones in the codex, in case i understood correctly? That would be the case yes, the most recently publication of points takes precident. Link to comment Share on other sites More sharing options...
SirJyo Posted May 28, 2021 Share Posted May 28, 2021 Would love to see some more interesting matched play missions ala goonhammer approved: destroy the moon. Don't think GW has it in them though other than in narrative play. Link to comment Share on other sites More sharing options...
Umbros Posted May 28, 2021 Share Posted May 28, 2021 Would love to see some more interesting matched play missions ala goonhammer approved: destroy the moon. Don't think GW has it in them though other than in narrative play. AOS has had excellent missions for the last three years (not perfect, but varied and interesting). Link to comment Share on other sites More sharing options...
Marshal Loss Posted May 28, 2021 Share Posted May 28, 2021 Tau/Nids: Necrons: G8Keeper, Kythnos and Khornestar 3 Back to top Link to comment Share on other sites More sharing options...
lash144 Posted May 28, 2021 Share Posted May 28, 2021 Custodes / AdMech FW G8Keeper 1 Back to top Link to comment Share on other sites More sharing options...
MagicHat Posted May 28, 2021 Share Posted May 28, 2021 AdMech unchanged. Custodes, caladius went down and telemon up by 20 pts. Necrons, Command barge and Nightbringer went up, shooty destroyers and Doomsday ark down. Reanimator down by 30 pts. Link to comment Share on other sites More sharing options...
gnalbel Posted May 28, 2021 Share Posted May 28, 2021 (edited) AdMech unchanged. Custodes, caladius went down and telemon up by 20 pts. Necrons, Command barge and Nightbringer went up, shooty destroyers and Doomsday ark down. Reanimator down by 30 pts. You are looking at a wrong list. Reanimator went down 30pts in the February Update, Nightbringer is unchanged as well. Edited May 28, 2021 by gnalbel Medjugorje and BLACK BLŒ FLY 2 Back to top Link to comment Share on other sites More sharing options...
dreadmad Posted May 28, 2021 Share Posted May 28, 2021 Immortals are the same price, and no change in cost of Tesla? Hopefully another fake, because that's unbelievably disappointing if it's accurate Link to comment Share on other sites More sharing options...
Oxydo Posted May 28, 2021 Share Posted May 28, 2021 Immortals are the same price, and no change in cost of Tesla? Hopefully another fake, because that's unbelievably disappointing if it's accurate Tesla is free according to that picture, which jives with the previous leaks and the WarCom article. Son of Carnelian 1 Back to top Link to comment Share on other sites More sharing options...
dice4thedicegod Posted May 29, 2021 Share Posted May 29, 2021 No change to necron low’s? Good news for the silent king. Bad news for obelisk and monolith Link to comment Share on other sites More sharing options...
ST.Lazarus Posted May 29, 2021 Share Posted May 29, 2021 Collection of changes from Reddit user: AmbitMicro Necrons Catacomb Command Barge +10 Entropic Lance (Chrono) +10 Tesla Immortals -2 Doomsday Ark -20 Lokhust Destroyers -5 Lokhust Heavy Destroyers -10 https://cdn.discordapp.com/attachments/653312544697483280/847913534498668594/193536264_4137842379638410_2212479052844980670_n.jpg https://cdn.discordapp.com/attachments/715628929205141554/847936754938019840/192033576_4137842506305064_6513593706231645048_n.png Admech FW - Unchanged Custodes FW Telemon +20 Caladius Grav Tank -20 https://scontent-dus1-1.xx.fbcdn.net/v/t1.6435-9/191927492_2892750550936761_103345033851965575_n.jpg?_nc_cat=111&ccb=1-3&_nc_sid=825194&_nc_eui2=AeG6oP2ygEnQU8mMEzS4vouVn47yY2CxC36fjvJjYLELfh2dUTVsv3kxlbcdtxc_oB_s4WEcrMYdPy_hudYD1LU5&_nc_ohc=cGOyqxxKFI0AX83Tuyc&_nc_ht=scontent-dus1-1.xx&oh=5cf50066775d82d0f1949b6dbfd01706&oe=60D759BB Tau FW Hazard Suits -5 https://m.imgur.com/xMiZCoi?r Nids Swarmlord -30 Tervigon -20 Stealers -2 Trygon Prime -15 https://media.discordapp.net/attachments/636845544706146324/847966409614557244/WhatsApp_Image_2021-05-28_at_23.png?width=511&height=910 https://media.discordapp.net/attachments/593183278404468743/847970255463907368/image0.png?width=420&height=909 Nids FW Dimachaeron +25 https://m.imgur.com/xMiZCoi?r GSC Jackals -2 Purestrains -2 https://media.discordapp.net/attachments/542340318083940362/847997890449244200/image-1.png?width=511&height=910 https://media.discordapp.net/attachments/542340318083940362/847997986566701086/image.png?width=1133&height=910 Dark Angels Talonmaster +15 https://media.discordapp.net/attachments/331548966485360642/847963866616299611/WhatsApp_Image_2021-05-28_at_23.04.40.jpeg?width=512&height=910 Dark Shepherd and BLACK BLŒ FLY 2 Back to top Link to comment Share on other sites More sharing options...
Dark Shepherd Posted May 29, 2021 Share Posted May 29, 2021 Deathguard are completely unchanged according to one of the comments Link to comment Share on other sites More sharing options...
Waking Dreamer Posted May 29, 2021 Share Posted May 29, 2021 I'm assuming TS and GK points changes would be with like 90% of their codex units right? Link to comment Share on other sites More sharing options...
Khornestar Posted May 29, 2021 Share Posted May 29, 2021 (edited) The WHC article seems to support that. Edited May 29, 2021 by Juggernut Link to comment Share on other sites More sharing options...
Marshal Loss Posted May 29, 2021 Share Posted May 29, 2021 Deathguard are completely unchanged according to one of the comments Hope this is true! I'm assuming TS and GK points changes would be with like 90% of their codex units right? Everything from their upcoming books. Dark Shepherd 1 Back to top Link to comment Share on other sites More sharing options...
Redcomet Posted May 29, 2021 Share Posted May 29, 2021 Chapter Approved isn't for updating rules. Right off the bat if you want rules changes you'll be let down. Only things you can hope for are costs adjusted to make units viable. There is a cost sweet spot where any unit can be useful. Sure but just making things cheap is poor games design. A Landraider is still not fixed if it dropped 100 points. It would just be cheap enough for people to overlook its flaws more easily. Medjugorje 1 Back to top Link to comment Share on other sites More sharing options...
Marshal Loss Posted May 29, 2021 Share Posted May 29, 2021 Unconfirmed information: Summary from discussion in the 40k discord overnight, no pics shown so can't confirm.Linebreaker goes to 2pts for one unit allowing partial scoringSimilarly psy ritual is now progressive rather than all or nothing for 3/7/12Domination changes to hold 3 and more than opponentScramblers progressive and 3pts per quarter so max 12Cut off the head removedWhile we stand we fight if units split and one dies only scores 3pts not 5Teleport homer now gives 2 for doing it in no man's landPierce the veil now 3vp per time doneMental interrogation now 24" but need line of sight (lol)Assassinate gives +1vp for killing the warlordMissions apparently identical, even the scouring. Karhedron 1 Back to top Link to comment Share on other sites More sharing options...
Dark Shepherd Posted May 29, 2021 Share Posted May 29, 2021 One of the goonhammerers said on twitter that no review/preview copies were sent out so no vids on it today, just some leaks via shops over the next few days is all we can hope for Link to comment Share on other sites More sharing options...
