Posted (edited)
large.Xenos-LoV.png.94032d2385dd7172606c
Greetings all leaders of the Kindred.
Call to Arms is back this year, with @Dr_Ruminahui running it again.  For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th!
The forum is split up into 5 Strongholds: Imperium, loyal Astartes, Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating.  For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for the new Rapid Deployment vow.
Check out the full rules here
If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout!
Edited by Dr_Ruminahui
  • 3 weeks later...
STRONGHOLDS OPEN JUNE 15, 2025
For the Full Rules and where to place your vows for the Leagues of Votann go to The Xenos Stronghold
Start Date: 15th June
End Date: 15th September
Here is a more detailed list of points per model specifically for the Votann
The below list should cover every model for the Votann (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them);
1pt    Hearthkin, Hearthguard, Bezerkers, Thunderkyn,
2pts   Pioneers
5pts   Sagitaur Transport
6pts   Hekaton Land Fortress
5pts    Einhyr Champion, Grimnir, Iron Master, Khal
Terrain
1pt    3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges
2pts   Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade
3pts   Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks
4pts   Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls
5pts   Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier
6pts   Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent
8pts   Fronteris Hab Bunker, Manufactorum Administratus,
10pts Zone Morialtis Gang Stronghold
Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing.
All points are per model. For example if you pledge 20 Hearthkin (1ptx20), 3 Pioneers (2ptsx3), a Sagitaur (5pts), and a Khal (5pts), your vow would be worth 36pts
Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Votann and Xenos to Victory!!!  After June 15th, please do the same in the Xenos Stronghold!
Rules and Place your Vow =>  The Xenos Stronghold
For those who haven't done so already and are able, please consider donating to Bolter and Chainsword, as the current fundraising drive has not yet met B+C's yearly financial needs.  All the mods and event organizers do their work out of love for the site, and the funds being raised are to keep the servers running and the software up to date.
  • 2 weeks later...
* ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS *
Happy painting!  Be sure to cheer on your fellow stronghold participants!
As a reminder, all vows must be completed by September 15th.
I will no longer be monitoring these faction rally points - if you have any questions, please ask me in the Strongholds, by messaging me, or by choosing my name from the dropdown menu when typing @ then my name (@Dr_Ruminahui).
Register a new account
Sign in
