Forteller Posted April 8, 2010 Share Posted April 8, 2010 Well ladies and gents i spent 9 hours down in the local hobby shoppe and i came up with one badass stormraven using only ONE valkyrie box! My goal was to do a stormraven as close to the source material the least amount of cash invested.Takes a bit of effort but the end result is fun and definetly worth it! Twin lascannon multimelta variation, has clamps in the back for the dreads which dont need magnets and just slide the dreadnought in place. If ya need any details on how i came to do it please respond and i ll will explain ;) P.S.: No green stuff,no styrofoam,just good old cutting and glueing. P.P.S.: Sorry for the picture quality i ll try to get some better ones. http://img15.imageshack.us/i/166yrp.jpg/ http://img697.imageshack.us/i/165tf.jpg/ http://img242.imageshack.us/i/164l.jpg/ http://img710.imageshack.us/i/162cj.jpg/ http://img121.imageshack.us/i/161cof.jpg/ http://img196.imageshack.us/i/160nz.jpg/ http://img197.imageshack.us/i/159st.jpg/ Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/ Share on other sites More sharing options...
Lestat Posted April 8, 2010 Share Posted April 8, 2010 Looks good. The Dread fits in well. My only quibble would be that the body of the Hawk seems too small to fit 12 Marines in - but then again, I still havn't worked out how you are supposed to fit 10 into a Rhino :) Any chance of a tutorial going up some time? Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/#findComment-2353786 Share on other sites More sharing options...
Forteller Posted April 8, 2010 Author Share Posted April 8, 2010 I ll try one later today or early tommorow,kinda bushed from modelling all day today ;) Keep in mind i ll try to make it step by step but pictures is kinda hard on the step by step,some imagination and my guiding and i think you ll be making your own in no time.... :) Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/#findComment-2353807 Share on other sites More sharing options...
Forteller Posted April 9, 2010 Author Share Posted April 9, 2010 Well here goes,its from the top of my head so no flaming please :) Use your imagination where my explaining seems to stop,you ll see it come along. A) For starters build the tail "sticks",engines, hull (which is basically front back floor roof and the little doors,NOTHING else), and the wings,but just assemble em. :) Flip the hull so the ramp faces the front, turn the tail sticks to the side and put them on the spot when the first vertical line appears on the side walls of the valkyrie's hull. C) Cut off the bit of the edges of the wings with a saw so they stick to the hull and flip them as the pictures suggest. Glue them so they start off as the same time as the tail "fins". D) Glue the connecting part of the back wings EXACTLY after the roof ends,in the back side of our hull. right BENEATH the tail "fins" ( This is so the back of the cockpit,for which we use the back of the original cockpit has something to rest on and look natural) E) Glue the engines where ya see them on the pics,not on the hull,on the wing a bit further away from the hull on top of the wings however. F) On this attempt, i cut off the cockpit to create my own,i cut the back off, where the second chair was located,kept the first frontal one and severely SEVERELY lowered it to the extent ya think the cockpit is inside the hull. (Warning THIS IS EASILY THE HARDEST PART OF THE WHOLE PROCCESS,YOU WILL FRACK IT UP, its understandable) you connect it to the original back of the cockpit which goes in the same place as it is shown in the instructions,only instead ya flip it and pull it a bit further back. G) Glue the tail wings by using the tail wings, the shorter ones put them vertically and the longer ones horizontally by forming a 90% degrees angle between them. Few pointers: A) dont be afraid to use any leftovers which are a lot to cover any exposed areas, this requires just some creativity and imagination and gives the aircraft a more natural look. :P Ofcourse weapon placement is easy, btw buy two valks with a friend of yours and have one use the "Barrel missiles" and the other use the regular ones so ya each get 4. ( If strapped just use the original missiles of the valk) C) I have made a little trick with the base placement. In the area where you connect the base to the plane. Instead of just putting it normally, i put a little "pillow" for the back part of the place where the base rests on.This forces it to sit on an angle instead of being straight, which gives it a totally new higher angle and makes it look MUCH MUCH cooler. D) use the "clamps" from what i understand is the landing gear to make sort of two coat hangars for the dreadnought which ya glue in the back of the vehicle and use them to slide the dreadnought in place without any use of magnets E) Dont be afraid to cut things with a saw or a cutter where it seems unnatural,the paint will fix the rest. Well basically thats it,dunno if i am forgetting something. If ya need clarification on ANYTHING or more details please dont be afraid to ask, i ' d love to help others make the same thing and not waste terrible amounts of cash on it :) I actually built two myself. Cheers Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/#findComment-2354132 Share on other sites More sharing options...
Forteller Posted April 9, 2010 Author Share Posted April 9, 2010 http://img11.imagehosting.gr/out.php/t1365891_005.jpg There now painted! Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/#findComment-2354504 Share on other sites More sharing options...
Justicar Valius Posted April 9, 2010 Share Posted April 9, 2010 Looks good. The Dread fits in well. My only quibble would be that the body of the Hawk seems too small to fit 12 Marines in - but then again, I still havn't worked out how you are supposed to fit 10 into a Rhino Any chance of a tutorial going up some time? 3 on one bench, 3 on the other, 3 standing up and the Serg sitting next to the driver. Love this, much better than the other pure Valk one I've seen on the net. Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/#findComment-2355243 Share on other sites More sharing options...
Tybrus Posted April 10, 2010 Share Posted April 10, 2010 really love it, just wish some step by step pictures where around. If anyone else builds one can you post some step by steps for those of us not as gifted as the above creater. Thanks.... Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/#findComment-2356054 Share on other sites More sharing options...
Kay Posted April 10, 2010 Share Posted April 10, 2010 Looks good. The Dread fits in well. My only quibble would be that the body of the Hawk seems too small to fit 12 Marines in - but then again, I still havn't worked out how you are supposed to fit 10 into a Rhino :P Any chance of a tutorial going up some time? you try to fit 8 terminators in a Land Raider hull... OnTopic Nice work on the stormraven, but i always imagined the Dread being carried underneath the stormraven, not on its back... But now that i think of it, i see a problem when landing in my idea... xD Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/#findComment-2356784 Share on other sites More sharing options...
Koyote Posted April 23, 2010 Share Posted April 23, 2010 I love your design. However, it appears that you used pieces from 2 Valkyrie kits. The flat piece that you placed on top of the tail sticks on either side of the cock pit are cut from the piece that normally serves as the cockpit's floor and underside of the Valkyrie's nose. Consequently, each Valkyrie kit only includes one such piece. I only mention this because as I build my own Stormraven, following your design, it took me a while to figure this out. Accordingly, I just wanted to give the next guy a heads up. Link to comment https://bolterandchainsword.com/topic/197599-new-stormraven-using-only-one-valkyrie/#findComment-2374757 Share on other sites More sharing options...
