turelhim vampire Posted June 24, 2010 Share Posted June 24, 2010 Greetings Frater! Some may have seen the Land Raider Ares I converted up in this forum, using the parts from the plastic vindicator kit. Well, not to be put off by the missing parts, I had a scrounge through my bits box for suitable replacements so the rest of the Vindicator kit didn't go to waste. Here are the results, all done and ready for painting: Comments and critique will be greatly appreciated. Link to comment https://bolterandchainsword.com/topic/204980-wip-vindicator-command-tank/ Share on other sites More sharing options...
Dan The Deamon Posted June 24, 2010 Share Posted June 24, 2010 That is awesome. I really like the use of bits from all sorts of vehicle kits. I see at least land raider, drop pod, and russ? You're making me want to change all my rhinos up to look like this. Good job. Link to comment https://bolterandchainsword.com/topic/204980-wip-vindicator-command-tank/#findComment-2444680 Share on other sites More sharing options...
little Posted June 24, 2010 Share Posted June 24, 2010 Nice battlecanon conversion. Only one question: Did you think the engine is a little bit big with regard to your tank? Furthermore, go you to protect it by an armour-plate or to leave it like that ? Link to comment https://bolterandchainsword.com/topic/204980-wip-vindicator-command-tank/#findComment-2444752 Share on other sites More sharing options...
turelhim vampire Posted June 24, 2010 Author Share Posted June 24, 2010 @Dan the Deamon: I used parts from... Vindicator, Predator, Baal Predator, Land Raider, and Leman Russ tanks, as well as parts from the Drop Pod kit. @little: I like the engine as it is, it goes with the exposed engine on my Ares to tie the two together, and makes use of one of the spare Razorback/Predator turret rings that come on every Rhino sprue. I have dozens of the damn things and wanted to find a use for one! :lol: Link to comment https://bolterandchainsword.com/topic/204980-wip-vindicator-command-tank/#findComment-2444992 Share on other sites More sharing options...
dizzy-xc Posted June 25, 2010 Share Posted June 25, 2010 I think it's super dumb to have an external loader. Looks ridiculous. Rest is super duper! Link to comment https://bolterandchainsword.com/topic/204980-wip-vindicator-command-tank/#findComment-2445091 Share on other sites More sharing options...
ephrael Posted June 25, 2010 Share Posted June 25, 2010 I love the engine you have there, I think it would look pretty good with some photo etched brass grills over the engine after you paint it. Link to comment https://bolterandchainsword.com/topic/204980-wip-vindicator-command-tank/#findComment-2445804 Share on other sites More sharing options...
