Caleth Posted April 30, 2011 Share Posted April 30, 2011 So I made a copy of a GK halberd using green stuff but it's increadibly flexible did I not mix up the GS right or should I be using something else? Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/ Share on other sites More sharing options...
Shadey Posted April 30, 2011 Share Posted April 30, 2011 GS will remain somewhat flexible. They usually mix in or use exclusively other putty like brownstuff or miliput if they want something sharper or harder. Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2742012 Share on other sites More sharing options...
mrtn Posted April 30, 2011 Share Posted April 30, 2011 You should probably have used an armature. Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2742153 Share on other sites More sharing options...
the Fell Hand Posted April 30, 2011 Share Posted April 30, 2011 Agree on all the points above, also you may try a heavy blue mixture, like 3:1 blue:yellow. That will cure harder. Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2742343 Share on other sites More sharing options...
Olis Posted April 30, 2011 Share Posted April 30, 2011 An armature would have been my first idea but the Fell Hand offers good advice; blue heavy greenstuff does cure harder (but it is slightly harder to sculpt with). Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2742539 Share on other sites More sharing options...
CarbonCopy Posted May 1, 2011 Share Posted May 1, 2011 Another option for a stiffer end product try this: Â First, mix a batch of green stuff. Then a batch of milliput of roughly equal volume. Then mix the two together. Â The resulting compound will squish into your mold easier and be very stiff after cure. I have used this combination quite a lot, so I know it works like a champ. Just make absolutely sure that your mold is very flexible or has ZERO undercuts, or you will never get the part out without destroying the mold. Â This is actually a great alternative to brown stuff. It's really easy to work and holds hard edges VERY well. Â The advantage over just milluput is that it don't crack, flake or fracture due to impact as easily as milliput. The advantage over just green stuff is that it's freakin' HARD and can more easily be sanded and filed. Â Less milliput, it's slightly more flexible and plastic-like after cure. Â Less greenstuff, and it's more soft during your working timeframe. It also ends up much harder and holds hard-edge detail better. Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2742859 Share on other sites More sharing options...
Caleth Posted May 3, 2011 Author Share Posted May 3, 2011 Wow, thanks for all the great replies I'll have to check out milput and brownstuff to see which works better for me. Â Again thanks for the advice. Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2745027 Share on other sites More sharing options...
mrtn Posted May 3, 2011 Share Posted May 3, 2011 You could start with an armature, buying a paper clip is cheaper than buying Milliput or brown stuff. ;) Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2745340 Share on other sites More sharing options...
pingo Posted May 3, 2011 Share Posted May 3, 2011 You could start with an armature, buying a paper clip is cheaper than buying Milliput or brown stuff. :) Â Storeowner: How can I help you? Caleth: One paperclip, please. Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2745734 Share on other sites More sharing options...
ShinyRhino Posted May 3, 2011 Share Posted May 3, 2011 Problem with a wire armature for weapons is that you still have blade edges and such to sculpt. GreenStuff alone will NOT hold an edge. Unless you're after a Nemesis Force Pugel Stick, go for Milliput or Brownstuff. Brownstuff cures rock-hard, and can be filed, sanded and carved after curing. Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2745767 Share on other sites More sharing options...
the Fell Hand Posted May 3, 2011 Share Posted May 3, 2011 GreenStuff alone will NOT hold an edge. Â 100% not true, sorry but yes it will hold an edge. If you get the right mixture and shape it then file after it cures, you can make any hard edge you want. I use the flat of an xacto blade to sand/file/smooth. Give it a try! Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2746137 Share on other sites More sharing options...
CarbonBased Posted May 3, 2011 Share Posted May 3, 2011 I use procreate sculpting putty for things like that. It works very well for holding edges. It's not quite as hard as brown stuff, but much firmer than green stuff. Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2746145 Share on other sites More sharing options...
Hemal Posted May 4, 2011 Share Posted May 4, 2011 I'd echo the milliput /GS mix - I use milliput with both pr-create and GS to help define edges Link to comment https://bolterandchainsword.com/topic/228719-stronger-green-stuff/#findComment-2746586 Share on other sites More sharing options...
