Black Templar Crusade
Nirach
Being the fool that I am, I decided to strip and re-paint my Black Templar crusade.
There's another unpictured squad, but they're bolter based, so pretty bland.
Crusade
http://i.imgur.com/r9kFs.jpg
Larger: http://i.imgur.com/Adx6x.jpg
Marshall
http://i.imgur.com/VtHO9.jpg
Larger: http://i.imgur.com/EeC0I.jpg
Emperors Champion
http://i.imgur.com/4KwKj.jpg
Castellan & squad (I'll be adding a Master of Sanctity (modified Chaplain in T.armour)
http://i.imgur.com/prPz1.jpg
Annd the venerable dread (FW), and the Chaplain in T.armour undergoing the modification. Stormbolter has been removed, and there will be a Thunder hammer going on there.
http://i.imgur.com/8Iw7W.jpg
As you can see, there's.. A lot of painting that needs to happen. Two land raiders done, three rhino's, and one predator. Everything else is WIP so far.
https://bolterandchainsword.com/topic/238338-black-templar-crusade/
Thanks chaps, hoping to get the castellan and his squad close to done tonight, but we'll see!
Yes, Cpt. Uriel Ventris, the Marshall is a Scibor mini - the "28mm Templar SF Knight #4" to be precise. I modified it's back, chopping off the Scibor power unit etcetera, and fitting a GW terminator one to make it believable that it's ~50% GW (I play most games in store).
That said, almost all my Thunderhammer/Stormshield combos are Scibor Templar shields, too. The castellans base is one of the Scibor "chaos carnage" bases - I really love the scibor stuff, but I can't shoehorn any more in than I already have at this stage.
It's actually just that the back of the terminator for the GK Dread Knight doesn't have a "hood" so to speak. It did have a little bit of one, but it looked really odd with a cloaked head
Yeah, I used GK parts to make Oblits out of, I understand what you're talking about there. As an IF player though I do love to see well-done BT armies, go forth my sons & purge!
It happened to be the only Terminator back I had >.>
Purge I shall! ;p
Speaking of;
Castellan is preeetty much done
http://i.imgur.com/3a0my.jpg
The squad, MoS, and Castellan:
http://i.imgur.com/URGs8.jpg
Been working on them some more, half built a drop pod, adding some (eight) bikers - Local GW hooked me up with the old three-pack with the metal bodied fellows. Four normal bikes, and one attack bike. I've also very nearly finished one squad:
http://i.imgur.com/GTdGC.jpg
http://i.imgur.com/5yZUU.jpg
http://i.imgur.com/2arla.jpg
http://i.imgur.com/YHa5F.jpg
Black Templar baneblade - need to do some more cleanup on the cross (it's airbrushed) and a :cusstone more detail work, but hey, it's a start
http://i.imgur.com/uUmjR.jpg
Engine hatches - done with scorched brown and weathering powders.
  • 1 month later...
I've not updated for a long time. I thought I'd show you why:
http://i.imgur.com/nCgJD.jpg
http://i.imgur.com/yQqdS.jpg
http://i.imgur.com/8ihfS.jpg
http://i.imgur.com/d0VIa.jpg
http://i.imgur.com/2LGr3.jpg
Someone got me to do a RS land raider and some troops, I wanted a break from the black, so off I trundled >.>
Of that lot, only the Apothecary is "done" in my opinion. I still need to do some matt varnish on some of the assault marines and detail on some others.
  • 1 month later...
Finally back on the Templar wagon, and I'm trying a cheaper, larger, command squad and Marshall - To see if there is any benefit over a terminator/terminator command squad.
Marshall with thunderhammer;
http://i.imgur.com/D9otE.jpg
Sacred Standard;
http://i.imgur.com/ny1sP.jpg
Both are WIP still.
