Thousand Sons project
Shuggnuggath
I have added some new images of painted stuff at the end of the thread. There are also some pictures of a scratch built Daemon Prince I'm making from styrene rod, miliput and greenstuff.
Woohoo! finally got the images to show.
I have decided to use the Dark Vengeance chosen to make some Thousand Sons Rubric marines.
I also sculpted a corrupted robot to use as an Obliterator, hes on a terminator size base btw.
https://bolterandchainsword.com/topic/263489-thousand-sons-project/
I plan to use converted chosen for all the rubrics, 2 squads of 9.
For the cultists I plan to use a combination of the DV cultists with empire flagellants and other bits to make a bunch of sorcerous dudes with robes and masks. The guys with flamers will be fire breathing/throwing cult wizards.
I had a rubric head in my bitz. I cut some rectangles of 1mm plasticard in roughly the right size and put one aside for scale in case I need to do more.
Then I carved and filed the rectangles into the appropriate shapes for the crests. They don't need to be identical, this is a chaos army :)
I glued the platicard crests to the helmets and waited for the glue to set. Once it was ready I added a thin even layer of greenstuff and scored the lines across. I then smoothed it down with a damp sculpting tool and left them to set. Later on I added very thin sausages of greenstuff to make the trims. I flattend the sausages a bit using a damp sculpting tool.
Then I carved and filed the rectangles into the appropriate shapes for the crests. They don't need to be identical, this is a chaos army :lol:
Thats great! I hope you don't mind if I steal your idea?
  • 2 weeks later...
I converted up a disc for my Sorcerer out of left over screamer parts. The sorcerer has magnetised feet so he can hop on and off. The body of the disc just need a bit of finishing off.
I also added a sorcerer for the second squad of rubrics. These guys should be getting painted up soon.
