Kierdale Posted January 24, 2015 Share Posted January 24, 2015 For many, herein lies an article which can safely be filed away under the title ` I Already Know.` A lot of us have smart or mobile phones with camera built in. Not a lot of us have what is required for high quality photographs of miniatures: really good digital cameras, light boxes, time and patience (I myself lack all four. Particularly the last two). However, all too often I see images posted of miniatures photographed with mobile phone cameras which are of pitifully poor quality. Bad lighting. Camera focused on the base or table. Camera focused on the keyboard behind the miniatures. Camera focused on the image on the book/miniature box behind/under the miniatures. Photo includes a lot of surroundings. Needs cropping. When you spent time painting miniatures to the best of your ability, isn’t it a shame you can’t present them a little better? If your painting isn’t all that good, if you can post reasonable images then other B&C members can give useful advice on how to improve your painting. The point of this tutorial is to show that it’s not that hard to take reasonable (dare I say decent?) images with the camera of a smart phone. Quickly too. Gear 1. Camera-equipped mobile or smart phone. If you have a digital camera, even a very basic one, you can improve your photographs with a bit more time and preparation. 2. Photographic background. Nothing fancy. A plain sheet of white paper under the miniature and curving up behind them will suffice, but a decent coloured one is better. Like the one you can download for free and print off from the B&C itself: http://www.bolterandchainsword.com/files/file/7-photo-background/ Or, as I recently discovered, a black sheet (okay, I admit it: actually a plain black dress shirt or T-shirt). White paper background. Photographic gradient background Black sheet background All three were taken with the same camera, in the same lighting, same position. But that last one came out awful, didn't it? So I tried this: Put a piece of white paper in the corner of the photo. And cropped it out. Far better. Optional You can of course get decent photos with your smart phone camera’s basic build in app (including cropping, on an iPhone), but personally I prefer an app with a few more options: cropping, at the very least and adjustable exposure if possible. I’m not into cameras at all and the word `photo exposure` used to make me grumble “Sounds complicated” and run away. But stick with me here. I use Camera+ (which will set you back all of a pound/couple of dollars/perhaps 200 yen?) but there are likely a lot of other good apps out there. By all means reply with suggestions. What to do I don’t have good light in my living room. A combined 30 & 38Watt double-ring light. I put the miniature on the background sheet somewhere as well lit as possible. Camera shake is also a problem so, if you don’t have some kind of tripod (I’ve seen some smartphone cases with built in tripods) then make sure you can rest your elbows/forearms against something to steady your hands as well as possible while you snap away. Of course, you could put your phone on a surface and use a timer, but I find I’m rarely able to get the angles I want that way. Now get reasonably close, but not so close that your camera can’t focus on the model (sounds obvious, but considering some of the blurred images I’ve seen...). Even the basic iPhone camera app will focus on whatever you tap on the screen, so tap about a bit until you’ve got it focused on the miniature (not the base. Often my camera picks up on the texture of the base and stubbornly tries to focus on that. Don’t fight the machine spirit. Guide it where you want it). Now, if you’re using Camera+ you can tap on the little plus in the top right of the focus box.... ….to lock the focus, then move the exposure circle around (alright, that photo's blurred terribly, but that's because I had to push the power and menu buttons simultaneously for a screenshot). Experiment with this as, moving the exposure circle to a dark area on the image will lighten everything (and can get you far lighter photos than you might first expect. Using the gradient background gives you lighter and darker areas to experiment with). You can also fiddle with exposure compensation, focus lock, exposure lock and white balance lock at the bottom of the screen. Not something I’ve yet fiddled with. Let’s keep this simple. So, you’ve got your image focused (and nicely exposed). So take some shots. If possible press the shutter icon lightly rather than snapping shots with the volume button, which will probably move the camera. As I said before, try to make sure your arms are braced firmly. And take at least two shots of each angle as one will probably come out badly. Once you’ve taken plenty of images from various angles (try standing the mini atop a paint pot for some shots from low angles. Just make sure the background sheet is always behind the mini, please!) you can put away the background and mini, grab a coffee and either email the photos to your PC for uploading or - with your camera app - do some cropping and fiddle with other options. Camera+ also lets you fiddle afterwards with not only the exposure but clarity, rotating/flipping, straightening (if you’re shots are a bit wonky), tints, duotone, soft focus, film grain (combined with the sepia filter and film-like frame you can put together some nice shots), sharpening, blurring, saturation, temperature, brightness and contrast, highlights and shadows and vignette. All: Lightbox -> Edit -> The Lab. Most of which I have never used because I haven’t the time and I just want some good, clear shots. As good as you can get with a digital camera and a light box? No. But decent, I hope. Razhabyuul, Interrogator Stobz, Vraxka and 13 others 16 Back to top Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/ Share on other sites More sharing options...
WarriorFish Posted January 24, 2015 Share Posted January 24, 2015 This is great, I will have to remember this next time I'm snapping away! Thanks Kier :) Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-3930622 Share on other sites More sharing options...
Sviar Posted January 25, 2015 Share Posted January 25, 2015 That was very helpful. Thanks Kierdale Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-3931532 Share on other sites More sharing options...
bigted Posted January 26, 2015 Share Posted January 26, 2015 Thanks for the tut! I'm stuck with a crappy smartphone camera and always have trouble getting good shots. This really helps! Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-3931930 Share on other sites More sharing options...
Augustus b'Raass Posted January 26, 2015 Share Posted January 26, 2015 Thanks dude! Awesome tut. I got here through the Night Lords thread, after I posted a link to this article (on our friends from Dakka Dakka) on miniature photography. This might also help those interested. :tu: Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-3932238 Share on other sites More sharing options...
Kierdale Posted January 26, 2015 Author Share Posted January 26, 2015 Thanks for the comments and the likes. I just hope it's helpful. Thanks dude! Awesome tut. I got here through the Night Lords thread, after I posted a link to this article (on our friends from Dakka Dakka) on miniature photography. This might also help those interested. :tu: And thanks for that link, Augustus. A good tutorial and I think a step more in depth than mine. For those who find my tutorial lacking, or too simple, I'd recommend that one. :tu: Augustus b'Raass 1 Back to top Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-3932468 Share on other sites More sharing options...
Black_out Posted January 26, 2015 Share Posted January 26, 2015 This was greatly helpful (I was the one linked in the NL thread lol) and I look forward to getting some better shots asap! Thanks for the tutorial! Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-3932499 Share on other sites More sharing options...
Father Mehman Posted February 7, 2015 Share Posted February 7, 2015 This is getting Bookmarked! Very nice stuff here! Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-3942819 Share on other sites More sharing options...
Stoic Raptor Posted February 11, 2015 Share Posted February 11, 2015 (edited) Lots of really good food for thought here. I usually do some balancing and cleanup in Paint.NET afterwards but my pics are still not as good as I'd like. I do not have a steady shutter finger and must use my HTC One for a camera. Hopefully these tips will help me improve my pics to the point where they are blog-worthy. Does anyone know of an Android app like this "darkroom" mentioned in the other thread? The only ones I saw of similar names were for actual chemical photo development. Edited February 11, 2015 by Ulfgrim Alvsbane Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-3947184 Share on other sites More sharing options...
Stoic Raptor Posted May 20, 2015 Share Posted May 20, 2015 I still intend to get a decent but affordable point-and-shoot digital camera for this purpose, but the thing that's most improved my photos is a good light box. I highly recommend the Foldio, it costs less than a Land Raider kit. I reviewed it in my blog: http://the-sage-brush.blogspot.com/2015/05/lights-camera-action.html Link to comment https://bolterandchainsword.com/topic/302515-taking-decent-photos-with-a-mobile/#findComment-4051189 Share on other sites More sharing options...
