The4thHorseman Posted September 15, 2015 Share Posted September 15, 2015 I've been searching high and low to see if anyone had made a tutorial on how you would actually do this, and found nothing. So far I've ben able to magnetize the Missle Pod Top and the Flamer/ Bolter Option on the Hull. The problem arises with the two weapon options, the autocannons and the plasma cannonades. Both have an ammo feed/ wire harness and a hopper. I currenty have each one of each weapon option and two sets of socket joints, one for each weapon option. How has anyone magnetized their arms and ammo and hopper to be interchangeable without being a bunch of little pieces? I know I could just not attache the ammo/ wire harness, and just mag the weapon and hoppers, but I'd rather not just do that. Any help would be greatly appreciated. Thanks. Link to comment https://bolterandchainsword.com/topic/313726-magnetizing-a-deredeo-dreadnought/ Share on other sites More sharing options...
Lorenzen Posted September 17, 2015 Share Posted September 17, 2015 http://orig15.deviantart.net/abbc/f/2015/260/7/0/deredeo_by_typhion-d99xsb3.jpg not the greatest picture in the world, but this is pretty much the simplest and best way to magnetize the deredeo and is the same way that Will Hayes magnetized his i used 4mm magnets on this one and got a really nice hold on the guns just sink the magnets into the arms & body as usual and you get a nice snug fit Hope that helps Link to comment https://bolterandchainsword.com/topic/313726-magnetizing-a-deredeo-dreadnought/#findComment-4174486 Share on other sites More sharing options...
The4thHorseman Posted September 18, 2015 Author Share Posted September 18, 2015 Ok. So you glued the weapon into the swivel joint? Then just maged at the ball joint? Also did you glue the hopper to the gun inself or is it just attached via the cables? Link to comment https://bolterandchainsword.com/topic/313726-magnetizing-a-deredeo-dreadnought/#findComment-4175168 Share on other sites More sharing options...
Lorenzen Posted September 18, 2015 Share Posted September 18, 2015 Yeah weapon is glued to the joint and the power supply/ammo hoppers are just glued to the cable/ammo feeds which are in turn glued to the guns. The less parts the better imho. Link to comment https://bolterandchainsword.com/topic/313726-magnetizing-a-deredeo-dreadnought/#findComment-4175245 Share on other sites More sharing options...
The4thHorseman Posted September 18, 2015 Author Share Posted September 18, 2015 Yeah weapon is glued to the joint and the power supply/ammo hoppers are just glued to the cable/ammo feeds which are in turn glued to the guns. The less parts the better imho. Thanks. This helps a lot. Link to comment https://bolterandchainsword.com/topic/313726-magnetizing-a-deredeo-dreadnought/#findComment-4175247 Share on other sites More sharing options...
