Order of the Sacred rose
Metic
How are you doing the white armour ?
I just followed the white scar tutorial Duncan did. Except I used a grey Vallejo Primer through airbrush. Based the model using ulthuan grey, washed the recesses with agrax earthshade, and then edge highlighted with White scar.
That face is amazing. how did you do it?
The skin is done using Cadian flesh tone, wash with reikland fleshshade. highlighted with cadian flesh tone, then highlighted again with about 60/40 pallid witch flesh/Cadian flesh tone I decided with this as the highlight because Kislev flesh/elf flesh is way too yellow IMO. I then used bloodletter to rosey up the cheeks, tip of the nose and her lips.
I honestly don't recommend doing eyes the way I did, it was a lot of failures and playing around a bit. I think I redid the eyes maybe 6 times. I use a wet pallete and very thinned down paint so I'm lucky they didn't turn out awful.
The eyes were blocked in with Vallejo dark sea green/blue it's almost black but not black, then I painted the whites using vallejo offwhite. After that I painted a small dot of purple in the middle, then a dot off center to that of Vallejo black grey.
