micahwc Posted June 24, 2017 Share Posted June 24, 2017 Based a lot on the towed 155mm I used to crew http://i.imgur.com/KnsPwD1.jpg http://i.imgur.com/ikqLEqx.jpg http://i.imgur.com/g2iW1dZ.jpg http://i.imgur.com/pTiv6aP.jpg Body is a two inch long piece of 1/2" copper pipe, barrels are from a pen, as is the recoil hydraulic thingy on top. Carriage is made from sprue pieces. Tow pintle is green stuff. Axle is another pen, wheels are bases glued together, elevation wheel is from a sprue, breech block is a piece of cork from a wine bottle that was trimmed to fit the 1/2" tube. Wheel brake is another piece of spruez Base plate is a larger base, and base plate extension is two pieces of sprue glued together. Got imperial armor index today so I have some guns to make now. Link to comment Share on other sites More sharing options...
Tallarn Commander Posted June 25, 2017 Share Posted June 25, 2017 Nice conversion! Your ability to sculpt greenstuff is impressive. Bill Kilgore and micahwc 2 Back to top Link to comment Share on other sites More sharing options...
micahwc Posted June 25, 2017 Author Share Posted June 25, 2017 Thanks. I redid the wheels a it and shortened the wheel base so they are closer to the gun and slightly farther back. I need to get it painted and start some earthshaker batteries. This was kind of a practice run. Link to comment Share on other sites More sharing options...
micahwc Posted June 26, 2017 Author Share Posted June 26, 2017 Looking at some Earthshaker batteries Dimensions given in the wikias are weird, and converted to 1/35 scale you get wonky numbers. For example, an Earthshaker cannon barrel inner diameter should be between 1/8" and 3/16". 5/32" is a hair large. That's closer to the size of a lascannon in game than to an actual Earthshaker. One set of dimensions for one pattern of Earthshaker, once converted to inches and 1/35 scale, is over 14" long and wide on the tabletop. Another is 9x4, which is probably what I will aim for. So the base will be roughly 4" square and the barrel will extend 7 inches from the center. I will fluff over the barrel diameter to make it larger, since it would be really tiny for game if I make it to scale. For reference, I just measured the pencil in front of me and it is about 1/4" diameter, so it would be considerably larger than an Earthshaker cannon's inner diameter. Link to comment Share on other sites More sharing options...
