Blissful Brushes Posted May 11, 2018 Share Posted May 11, 2018 It's been a very long time since I picked up a brush or indeed, a sculpting tool, but I am now back - at least for the next couple of months. I never have the patience to build full armies and truth be told, there is not really much point as I haven't played the game since I was about 11 and don't intend on doing so in the future; I just enjoy the stories and the models. So far this is no model for the Emperor, and when he is eventually built presumably it'll be a Siege of Terra/Vengeful Spirit era model, this leaves me a tasty loophole to play with. Most of the Emperor's work happens long before the Siege of Terra but still begins on Mother Earth, so that's where we're starting. I'm building a model of the Emperor themed around the Unification of Terra. It's in its very early stages and it's also the first time I've attempted to sculpt a full model from scratch. Below are the images of the progress that I've made so far: Not much so far, the final image is a scale shot - on the right is a standard FW marine and on the left is a slightly heightened Ultramarine. I'm aiming for the armour to be a fairly ornate cross between MkI and MkII power armour and the Custodes artwork - not those horrible models that were released last year. This will be the Emperor as a primal warlord rather than the noble leader of mankind. C&C welcome though be gentle - it's been a long 'ole while. Link to comment https://bolterandchainsword.com/topic/347180-the-emperors-beginnings/ Share on other sites More sharing options...
Bluedoo Posted May 11, 2018 Share Posted May 11, 2018 This looks promising, I can't wait to see where it goes. I like your idea of a primal Emperor. What kind of sculpting clay are you using? Link to comment https://bolterandchainsword.com/topic/347180-the-emperors-beginnings/#findComment-5078780 Share on other sites More sharing options...
Krakendoomcool Posted May 11, 2018 Share Posted May 11, 2018 Wow this is ambitious. Looking forward to seeing how this goes. Link to comment https://bolterandchainsword.com/topic/347180-the-emperors-beginnings/#findComment-5078805 Share on other sites More sharing options...
Blissful Brushes Posted May 14, 2018 Author Share Posted May 14, 2018 This looks promising, I can't wait to see where it goes. I like your idea of a primal Emperor. What kind of sculpting clay are you using? Thanks, I think it's something that hasn't been done before so it should be an interesting compromise between two sets of artwork. The clay that I'm using is called Plastiline from http://plastiline.fr Warning: Doesn't cure, can't be baked Wow this is ambitious. Looking forward to seeing how this goes. Thanks Picture update tonight. I probably should have tested this before I worked up almost ⅔ of a Custodes sprue and the beginnings of this Emperor model, but the plastiline that I'm using does not cure on its own - I knew this, but I did assume that it could be baked, not so with oil based clays. What this means is that I am going to be making my first forays into casting which is a little bit worrying to tell the truth. Specifications of the mould material: - Must be liquid - Must cure naturally rather than in the oven etc. Specifications of the resin: - Must be pourable - Must cure naturally I profess to be a total amateur in this theatre, so if anybody has advice on this front I would be greatly appreciative!!!! Scope of this project: Pre-unity Emperor My Emperor model is based off this image pose-wise but is going to be a little bit less ornate. At the moment it's a toss up between making it look like early pattern Power Armour or armour that isn't going to fully enclose him - Knight vs Space Marine. He will also likely be helmed or have a death-mask because I can't for the life of me sculpt faces yet, unless I can manage to cast a Fulgrim head and convert it. Thunder Warriors - 05 x Thunder Warriors (Heavy support) - 05 x Thunder Warriors (bolter) - 10 x Thunder Warriors (melee) As I'm intending on making multiple models I think I'm going to try and make a sprue of the main parts of these so that I don't have to sculpt each one from scratch. - Torso Front + Back - Left leg + Right - Knee - Left arm + Right - Head(s) 4 Legio Custodes (Guardian Spears) These will be made out of the beginnings of the sprues that I had started to make a couple of years ago rather than the ones from the box set because truth be told, I'm just not a fan, they look too caricatured and cartoony - they just don't fit in with the HH from ForgeWorld. This is what I'm working with on the Custodes front at present: Torso Shoulder pad Helmet C&C Welcome as ever Link to comment https://bolterandchainsword.com/topic/347180-the-emperors-beginnings/#findComment-5081452 Share on other sites More sharing options...
