Rogue Crusader Posted August 27, 2018 Share Posted August 27, 2018 Kicking off work on my Primaris Marines with some conversion work on my Aggressors. After seeing some other conversions using Taurox barrels I wanted to replace my Aggressors boltstorm barrels with something a bit more dynamic. I had some spare Red Dog Minis autocannons laying around so I tried a test fit and decided that they paired up quite well. The modification is pretty simple, first I removed the boltstorm barrels on each arm along with the small secondary rod that is right next to it being careful not to damage the lip that helps form the knuckle of the power fist. Once that was removed I carefully scraped and filed the surface so it was flat. I removed the forward section of the autoncannons with a jewelry saw, then using a knife and file to clean up the backside making sure it was flat and level. Then I simply glued them in place. Even if your model is already built the barrels are easy to remove and upgrade. IMO it gives them a much more aggressive and threatening profile and also looks like it can pump out the withering amount of bolter fire that the ammo feed belts would suggest. Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/ Share on other sites More sharing options...
Reyner Posted August 27, 2018 Share Posted August 27, 2018 Phwoar that looks so much better than piddly little bolters! Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5154580 Share on other sites More sharing options...
Paradogmatic Posted August 27, 2018 Share Posted August 27, 2018 I've been seeing these around the last month or so -- I'm glad I haven't painted my Aggressors yet because I'm pretty sure I need to do something like this. Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5154696 Share on other sites More sharing options...
Bjorn Firewalker Posted August 27, 2018 Share Posted August 27, 2018 On 8/27/2018 at 10:42 AM, Reyner said: Phwoar that looks so much better than piddly little bolters! I second that. Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5154937 Share on other sites More sharing options...
SystemSyn Posted August 28, 2018 Share Posted August 28, 2018 Very cool! The weapons look so much more substantial with your conversions Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5155328 Share on other sites More sharing options...
Custom Hero Posted August 29, 2018 Share Posted August 29, 2018 Nice upgrade. Looks the part, and in my opinion, better than the original. Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5155909 Share on other sites More sharing options...
Rogue Crusader Posted August 29, 2018 Author Share Posted August 29, 2018 Glad you guys like them :) I finished converting and priming the rest of the squad so they are now ready for paint. Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5155939 Share on other sites More sharing options...
Silas7 Posted August 29, 2018 Share Posted August 29, 2018 Boltstorm gauntlets are an odd pair, for instance I like your conversion it really emphasizes the ranged firepower but while doing so I get this nagging thought of how unwieldy it would be to fight in CC with those barrels eclipsing the fists. Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5155942 Share on other sites More sharing options...
Bjorn Firewalker Posted August 29, 2018 Share Posted August 29, 2018 On 8/29/2018 at 2:23 AM, Silas7 said: I get this nagging thought of how unwieldy it would be to fight in CC with those barrels eclipsing the fists. Good to know I'm not the only one who noticed. Boltstorm chainfists might be a better option, especially if some kind of muzzle brake/handguard is added, to prevent foreign objects- the enemy's torn flesh and shattered bones- from obstructing the gun barrels. Any takers? Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5155952 Share on other sites More sharing options...
Warsmith Uveron Posted August 29, 2018 Share Posted August 29, 2018 On 8/29/2018 at 2:23 AM, Silas7 said: Boltstorm gauntlets are an odd pair, for instance I like your conversion it really emphasizes the ranged firepower but while doing so I get this nagging thought of how unwieldy it would be to fight in CC with those barrels eclipsing the fists. I think the Rule of Cool wins out, as long as its a common Rule across the rest of the army. And anyhow, the Power fist is superposed to be a weapon that grabs and rips, and I cans still see that working. As much as it works on another Power fist. Link to comment https://bolterandchainsword.com/topic/349892-primaris-aggressor-upgraded/#findComment-5156128 Share on other sites More sharing options...
