Prot Posted January 8, 2019 Share Posted January 8, 2019 Hey guys, Just curious as I've been having fun testing the new Maniple Servitor specialist detachment (I think it's called?). The problem is Servitors by GW are super expensive, but I need to build some new ones that would be 'legal' for all GW play and I'm wondering if any of you have done some kit-bashing? The only 'bits' I can come up with are from the Datasmith(s) that I have on sprue from the Katellan box set. I have one built and painted but will probably never use the others. Any other ideas for cool sources of Servo based Servitors? Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/ Share on other sites More sharing options...
Charlo Posted January 8, 2019 Share Posted January 8, 2019 Skitarii has some gubbinz you can use and the Kataphon box is brimming with mechadendrites and extra bits you can slap on them. For the main body just Cadian/ Catachan Guardsmen aren't bad as they're pretty low-key but chunky humans to work from as a base. Maybe Kharadron Overlords from AoS could be worth a look? Cool fluff could be they were some remaning Squat corpses that the Ad Mech "put to use". Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230684 Share on other sites More sharing options...
Iron-Daemon Forge Posted January 8, 2019 Share Posted January 8, 2019 Hey guys, Just curious as I've been having fun testing the new Maniple Servitor specialist detachment (I think it's called?). The problem is Servitors by GW are super expensive, but I need to build some new ones that would be 'legal' for all GW play and I'm wondering if any of you have done some kit-bashing? The only 'bits' I can come up with are from the Datasmith(s) that I have on sprue from the Katellan box set. I have one built and painted but will probably never use the others. Any other ideas for cool sources of Servo based Servitors? Prot - If you search for the Warhammer World titan display, shown off the FW Warlord titan. There a lot of cool servitor conversion. From what I remember it pretty much Genestealer Cult & standard Mechaicus kits. I try get some of the photos I've taken & get them posted up later today. Prot and Battybattybats 2 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230693 Share on other sites More sharing options...
Dragonlover Posted January 8, 2019 Share Posted January 8, 2019 The chainsword from a Sentinel would make a pretty cool servitor arm. Dragonlover Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230713 Share on other sites More sharing options...
Prot Posted January 8, 2019 Author Share Posted January 8, 2019 Some interesting ideas already guys. Thanks! Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230726 Share on other sites More sharing options...
Dark Bjoern Posted January 8, 2019 Share Posted January 8, 2019 (edited) I build 16 of this guys. It took some time to get all the necessary bits but it was worth the time. http://i186.photobucket.com/albums/x120/DarkBjoern/Knights%20and%20Titans/Engineseer%20Auxillia%2001%20WIP%2002_zpsjxkbd7qm.jpghttp://i186.photobucket.com/albums/x120/DarkBjoern/Knights%20and%20Titans/Engineseer%20Auxillia%2001%20WIP%2003_zpsfmbwby7j.jpghttp://i186.photobucket.com/albums/x120/DarkBjoern/Knights%20and%20Titans/Engineseer%20Auxillia%2001%20WIP%2004_zpsje2ymrap.jpghttp://i186.photobucket.com/albums/x120/DarkBjoern/Knights%20and%20Titans/Engineseer%20Auxillia%2001%20WIP%2005_zpsj0q8ini0.jpg Edited January 8, 2019 by Dark Bjoern frosteldar, Prot, Azekai and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230773 Share on other sites More sharing options...
Magos Takatus Posted January 8, 2019 Share Posted January 8, 2019 I can't remember who it is that makes them, but somebody on this forum has some top notch servitors made from Genestealer cultist bodies and legs, augmetic arms from the Kataphron Destroyer weapons and the Destroyer Phosphor Blaster guns cut down into rivet guns. They absolutely look the part and if I could remember who's blog it was I'd provide the link. Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230786 Share on other sites More sharing options...
Gederas Posted January 8, 2019 Share Posted January 8, 2019 (edited) I've seen this Praetorian Battle Servitor when looking for inspiration for my Ordo Machinum stuff for Inq28: They're bigguns too: According to the guy the parts list was: "The Parts list mostly comprises a Kataphron Breacher kit and a heavily modified Slaughterpriest from the fantasy line, with skitarii and electro-priest parts. The heavy bolter is actually taken from a Sisters of Battle vehicle sprue because of the ammo drum, but any imperial guard heavy bolter that isn't embedded in the hull of a tank is fine." Edited January 8, 2019 by Gederas brother_b 1 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230792 Share on other sites More sharing options...
Magos Takatus Posted January 8, 2019 Share Posted January 8, 2019 Wow, that really looks impressive. The parts appear to be in scale with each other. Those Slaughterpriests must be massive! Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230796 Share on other sites More sharing options...
Redtoof Posted January 8, 2019 Share Posted January 8, 2019 I suspect there is some mileage in using the GS Cult minis and replacing the hybrid parts with Kataphron spares. Also I think several of the Poxwalkers could be de-nurgled a bit and would be good base models for servitors. Finally the AoS zombies and ghouls make good starting points for various servitor conversions. Prot 1 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230821 Share on other sites More sharing options...
Gederas Posted January 8, 2019 Share Posted January 8, 2019 Wow, that really looks impressive. The parts appear to be in scale with each other. Those Slaughterpriests must be massive! I can confirm, they're huge. In fact, Slaughterpriests are TALLER than Primaris Marines. In my WIP thread, you can see my kitbashed based on Krieg from Borderlands 2 and he's very obviously taller than the Primaris to his left. Stercus and Magos Takatus 2 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230871 Share on other sites More sharing options...
sockwithaticket Posted January 8, 2019 Share Posted January 8, 2019 The Talos kit has some mechandrite/bionic arm looking bits. Prot and Magos Takatus 2 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230922 Share on other sites More sharing options...
Stercus Posted January 8, 2019 Share Posted January 8, 2019 Wow, that really looks impressive. The parts appear to be in scale with each other. Those Slaughterpriests must be massive! I can confirm, they're huge. In fact, Slaughterpriests are TALLER than Primaris Marines. In my WIP thread, you can see my kitbashed based on Krieg from Borderlands 2 and he's very obviously taller than the Primaris to his left. Slaughterpriests are big. I used one that came free on a white dwarf to make an ogryn. Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230925 Share on other sites More sharing options...
Magos Takatus Posted January 8, 2019 Share Posted January 8, 2019 Gederas, your Borderlands 2 homage is fantastic. I'm glad I'm not the only one seeking inspiration from that game. I've got an Ork with a gun painted like a Torgue Legendary gun in my Ork plog. :) Sockwithaticket had a good point. I've been meaning to pick up a Talos to harvest it for bits for a Magos. I haven't managed to justify the cost even if I'll probably be able to put a Chronos on display after I've got the bits I'm looking for. Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5230967 Share on other sites More sharing options...
crazy_tuco Posted January 8, 2019 Share Posted January 8, 2019 I'm about to start work on converting the Goliath half of the Necromunda box into a unit of servitors using parts from used Kataphron sprues, used electro-priest sprues, used Skitarii sprues, etc. Possibly some stuff clipped from the old Zombie sprues for WFB. Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5231057 Share on other sites More sharing options...
BolterZorro Posted January 8, 2019 Share Posted January 8, 2019 What's about cultist? they are cheap £$€ and you don't need tons of them: only 4 or 8 maybe, all pretty much naked (with a servo arm preferably) Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5231103 Share on other sites More sharing options...
Burni Posted January 8, 2019 Share Posted January 8, 2019 What about the Delaque as a base? Bald head and goggles could be a good start. Or maybe they look a bit too tech-priest-y... Battybattybats 1 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5231113 Share on other sites More sharing options...
BolterZorro Posted January 9, 2019 Share Posted January 9, 2019 What about the Delaque as a base? Bald head and goggles could be a good start. Or maybe they look a bit too tech-priest-y... It can be a good idead especially with the coat painted the same coulour as the vanguard/rangers to unit the look of the army. Maybe add a back pack and a servo arm... Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5231542 Share on other sites More sharing options...
Burni Posted January 10, 2019 Share Posted January 10, 2019 Been thinking a bit more about this as it's something I'd like to do also. What about the Van Saar bodies (and some of the masked heads). Some of them are running which isn't ideal but combined with some Delaque heads, they might look good. Maybe grab a SM Dev squad for the weapons and backpacks and sprinkle in some AdMech arms and bits and you should be somewhere close? And you can use the Delaque bodies to make a couple of variant TPE's with Skitarii heads so you don't have to have so many of the same old TPE model. Once I'd through my current painting, I might give that a go! Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5232268 Share on other sites More sharing options...
Magos Takatus Posted January 10, 2019 Share Posted January 10, 2019 Y'know I said I was thinking about buying a Talos and using the spare parts for Admech conversions? Oops, I kinda purchased one today. It looks like there will be lots of vials and small mechanical arms that will come in handy. I'm assembling a Cronos. I willtake a picture of the parts that are left afterwards later if that would be useful? Burni 1 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5232599 Share on other sites More sharing options...
Prot Posted January 11, 2019 Author Share Posted January 11, 2019 Thanks for so many great ideas everyone. Lots of great inspiration here too. And by all means if there’s more, please post it. I have just finished a massive AdMech project I started before the Christmas break and I’m dying to start this servitor project. I love the idea of using spare Kataphron bionics as I don’t really make Breachers, however for the body I prefer something a bit smaller. I want to be able to keep them about the same height as the original servitors so they fit on 25mm bases and have a chance of being hidden. (They scream first strike). So what I’m getting from you guys is I should look at Chaos Cultists (I have quite a few), GSC dudes (I don’t have any) and Poxwalkers (I have quite a few ). Battybattybats 1 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5232710 Share on other sites More sharing options...
Subtle Discord Posted January 11, 2019 Share Posted January 11, 2019 I've posted this image in another thread or two talking about kitbashing Servitors so I apologize if you've already seen it, but I think it does a nice job illustrating how well the GSC Neophyte models can be bashed into very good Servitors. These are made from the leftover bits from the Kataphrons with a Skitarii backpack. After filing it down as much as possible, a round detail can be placed right on the GSC symbol and it simply disappears with no other work. With the new rules, I suspect I'll be making several more of these in the somewhat near future; a fabricators work is never done, so many projects to construct never enough time! brother_b, Azekai, Vel'Cona and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5232771 Share on other sites More sharing options...
MajorNese Posted January 11, 2019 Share Posted January 11, 2019 What about the Delaque as a base? Bald head and goggles could be a good start. Or maybe they look a bit too tech-priest-y... It can be a good idead especially with the coat painted the same coulour as the vanguard/rangers to unit the look of the army. Maybe add a back pack and a servo arm... Dammit, you make me buy even more plastic...the delaque box seems almost perfect for a ridiculous amount of TPEs - robes, bionic heads, scale that makes skitarii parts/bionics fit. Add a skitarii backpack with a servo arm, replace guns with laspistols, and all that's missing is the axe. Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5232791 Share on other sites More sharing options...
Magos Takatus Posted January 11, 2019 Share Posted January 11, 2019 I've posted this image in another thread or two talking about kitbashing Servitors so I apologize if you've already seen it, but I think it does a nice job illustrating how well the GSC Neophyte models can be bashed into very good Servitors. These are made from the leftover bits from the Kataphrons with a Skitarii backpack. After filing it down as much as possible, a round detail can be placed right on the GSC symbol and it simply disappears with no other work. With the new rules, I suspect I'll be making several more of these in the somewhat near future; a fabricators work is never done, so many projects to construct never enough time! Ah, it was you I was trying to remember who made those conversions. They are top notch. :) Subtle Discord and Captain Caine 24th 2 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5232809 Share on other sites More sharing options...
Magos Takatus Posted January 15, 2019 Share Posted January 15, 2019 As promised, Here's the leftover parts after building a Kronos. I did lose one small hooked arm since the small grey plastic piece fell on my large grey carpet and somehow shifted into another dimension before I could start searching for it. There's loads of jars, vials and assorted bits as well as mechanical arms that would suit a Magos or some Servitors nicely. Prot 1 Back to top Link to comment https://bolterandchainsword.com/topic/352988-kit-bash-servitor-ideas/#findComment-5235421 Share on other sites More sharing options...
