Kilofix Posted July 3, 2019 Share Posted July 3, 2019 Here’s the doc for my Nemesis Warbringer ETL vow. It’s currently soaking to remove the resin release. Thats the body. There’s a second tub for the weapons and head. Normally I wouldn’t recommend doing it like this (all the parts disorganized) but I’ve assembled a bunch of Titans before and this is for expediency. I think the soak / scrub and cleanup prep will really take the longest actual work time. Assembly should take 3-4 days duration but it’ll only be a an hour or so of work a day before letting it set. And paint I expect to only take a few hours with an airbrush given its size (excluding details, decals, etc.). I’ll post pics and descriptions as I put it together. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/ Share on other sites More sharing options...
Warbringer Posted July 3, 2019 Share Posted July 3, 2019 Looking forward to seeing this, my friends are trying to convince me to get one as its my online handle namesake Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5341461 Share on other sites More sharing options...
Kilofix Posted August 8, 2019 Author Share Posted August 8, 2019 Progress Also added the hip hydraulics, cables and bolters but no pics. At this point the body is mostly done, except for leaving some plates off to paint before assembly. On to the weapon arms, main cannon, AA guns and head. Should be done on time. Also wanted to plug my AT: http://www.bolterandchainsword.com/topic/350529-legio-suturvora-wip/ Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5361828 Share on other sites More sharing options...
Kilofix Posted August 9, 2019 Author Share Posted August 9, 2019 Everything magnetized. Quake Cannon, AA guns, Mauler Bolters and arms all rotate and the former elevates. Head detaches and opens. Not pictured but the ammo loading deck arms move too. Pretty much done building. Painting the plates separately before attaching but have lot of green stuff gap filling to do before then. Still looking to be done on time. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5362867 Share on other sites More sharing options...
Captain Semper Posted August 9, 2019 Share Posted August 9, 2019 OMG!!!! IT STANDS!!! AWE-INSPIRING STUFF! Do you think you'll be able to complete it for the ETL? It looks as if there is a ton of detail on it... Whatever you do, don't rush it! :lol: Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5362882 Share on other sites More sharing options...
Kilofix Posted August 9, 2019 Author Share Posted August 9, 2019 OMG!!!! IT STANDS!!! AWE-INSPIRING STUFF! Do you think you'll be able to complete it for the ETL? It looks as if there is a ton of detail on it... Whatever you do, don't rush it! :lol: Yeah. Painting is the easy part lol. 2 days tops. Scrubbing, trimming, green stuff was the time consuming bit. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5362903 Share on other sites More sharing options...
Kilofix Posted August 11, 2019 Author Share Posted August 11, 2019 My bulldog was trying to assist me last night but seeing as his paws are unwieldy and lacking opposable thumbs he accidentally knocked the Titan off my 3’ table. Surprisingly the only piece that broke was a toe (plates hadn’t been attached yet). Encouraged by the effectiveness of my previous pinning, I’ve gone slightly overboard and added another 32 pins. If there’s such a thing as “over-pinning”, this is probably the case for it but never let it be said that I was not thorough. I also drove a 3 inch pin through the one toe that broke all the way through the foot and shin. Just because. Priming now. Pics of pinning and paint again shortly. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5364872 Share on other sites More sharing options...
Kilofix Posted August 22, 2019 Author Share Posted August 22, 2019 Put pins right through his foot all the way through his shin: More pins all over the place. This is before covering up / smoothing over with green stuff and clearing the excess glue. Testing articulation of the loading arms and magazines: Almost done really, just need to finish some trim on the top, reattach the plates and add decals: Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5372820 Share on other sites More sharing options...
Kilofix Posted August 23, 2019 Author Share Posted August 23, 2019 Something has gone wrong Because his stance is so wide, I actually had to trim the bottom of his inner shin plate Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5373250 Share on other sites More sharing options...
Kilofix Posted August 24, 2019 Author Share Posted August 24, 2019 Just waiting on decals to be applied tonight then weather and airbrush barrel heat discoloration: Loading shells (it’s articulated so posable): I’ll get some better pics, lighting and setting after decals and stuff. Should be done well in time for ETL end. If bulldog doesn’t eat it. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5373661 Share on other sites More sharing options...
Bjorn Firewalker Posted August 24, 2019 Share Posted August 24, 2019 The Titan's coming along well. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5373674 Share on other sites More sharing options...
Brother Carpenter Posted August 25, 2019 Share Posted August 25, 2019 Nice! There's no detailled interior as with the warhound? Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5373990 Share on other sites More sharing options...
Marshal Rohr Posted August 25, 2019 Share Posted August 25, 2019 Amazing work, Kilo. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5374076 Share on other sites More sharing options...
helterskelter Posted August 25, 2019 Share Posted August 25, 2019 That is a mighty model indeed! Love the scheme so far Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5374159 Share on other sites More sharing options...
Kilofix Posted August 25, 2019 Author Share Posted August 25, 2019 Heat discoloration. I think the black band is too thick, I’m going to back it off a little before I finish: This thing has less space than my bathroom, but it has a throne: Didn’t you say this was a new Titan? Why are the seats used? More loading stuff: Excuse my terrible work desk. Will take better pictures next weekend with terrain. But painting-wise - I’m going to call it complete: Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5374350 Share on other sites More sharing options...
Bjorn Firewalker Posted August 26, 2019 Share Posted August 26, 2019 The detailing is well done. The Titan's various components look so metallic. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5374527 Share on other sites More sharing options...
librisrouge Posted August 26, 2019 Share Posted August 26, 2019 I'm in love. You did a great job with that titan and should be proud of it. I love it. Link to comment https://bolterandchainsword.com/topic/356940-nemesis-warbringer-etl-vii/#findComment-5374877 Share on other sites More sharing options...
