Beams Posted July 12, 2021 Share Posted July 12, 2021 (edited) So, I wish I could take credit for the Idea, but I went: "Paragons are... disappointing, but my Sacresants were not? It would also be really cool to have something fast, like Zephyrim or Seraphim, to take objectives..." and then when I was talking to my brother about our armies, and how it's kind of lame that they took Calvary (Rough Riders) from Imperial Guard to give to Ad Mech, of all armies? I was like, "Sisters are basically french knights! Like, if they were going to give Cavalry to anyone, why not the French Knights?" So then I looked through the AoS units, until I found one that I liked. At first, I was going to use the Chaos/Slaves to Darkness Chaos Knights but felt they'd take too much work to get rid of the symbols, and that the horses look slightly off? So I kept looking until I found Lumineth Dawn Riders. The Horses are less bullky, more streamlined, and have less spikes and paraphenlia that would have to be shaved off. So I googled it to see if anyone else had done it, if it was do able, and it looked like it was. So I went to the store, grabbed a box and started cutting up the pieces. Once the green stuffs dry to connect the torso to the legs, I will start painting these Zeryphim, hopefully I can use them in my next game to replace the very disappointing Paragons, and to help bully some objecives. Edited July 31, 2021 by Beams Joukernaut, NKirkham24, 9x19 Parabellum and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/ Share on other sites More sharing options...
9x19 Parabellum Posted July 12, 2021 Share Posted July 12, 2021 Heyo! I think the modelling/conversion is fantastic. I'm a bit baffled though as to how you intend to 'force' them into a paragon warsuit. -Paragon warsuits are 8"...cavalary type stuff tends to be 10-14" of movement. -The bases you are using are off -Paragons are T5...I suppose you could say that being on a horse increases T by 2. -Paragons are W4...kind of a stretch that saddling a horse gives +3 wounds.... -Then the big problem...how do you fit 2 storm bolters and a heavy bolter / heavy flamer / multi-melta onto the horse's rigging? Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5719137 Share on other sites More sharing options...
Beams Posted July 12, 2021 Author Share Posted July 12, 2021 (edited) Heyo! I think the modelling/conversion is fantastic. I'm a bit baffled though as to how you intend to 'force' them into a paragon warsuit. -Paragon warsuits are 8"...cavalary type stuff tends to be 10-14" of movement. -The bases you are using are off -Paragons are T5...I suppose you could say that being on a horse increases T by 2. -Paragons are W4...kind of a stretch that saddling a horse gives +3 wounds.... -Then the big problem...how do you fit 2 storm bolters and a heavy bolter / heavy flamer / multi-melta onto the horse's rigging? I'm not? They are Zeryphim. Power Lance instead of Power Sword, but also swords on their hips, 12" Movement. Only gun is a holstered pistol. I dislike Paragons greatly. They are to replace the Paragons that I had, because I had a very bad experience with Paragons, and refuse to ever take Paragons ever again. Edited July 12, 2021 by Beams Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5719143 Share on other sites More sharing options...
9x19 Parabellum Posted July 12, 2021 Share Posted July 12, 2021 Well then that solves that problem! Carry on! (Bases might still be a problem though). Beams 1 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5719162 Share on other sites More sharing options...
Beams Posted July 12, 2021 Author Share Posted July 12, 2021 Well then that solves that problem! Carry on! (Bases might still be a problem though). Yeah, the bases are a little larger than standard Zephyrim, but if I go any smaller, on bases they will definitely fall over! Since we mostly just play casual games, it shouldn't be an issue, except maybe fitting them in when I deepstrike. Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5719177 Share on other sites More sharing options...
Bonzi Posted July 12, 2021 Share Posted July 12, 2021 Your only other game play problem is a flying model represented by a horse. It's gonna be a touch odd to see calvary leaping from roof top to roof top. Otherwise a really great looking conversion. 9x19 Parabellum 1 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5719197 Share on other sites More sharing options...
Joukernaut Posted July 13, 2021 Share Posted July 13, 2021 Fun conversion! I see no problem in this working out if you play casual with friends. love to see more of these ideas, keep it up! Beams 1 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5719628 Share on other sites More sharing options...
Beams Posted July 31, 2021 Author Share Posted July 31, 2021 Added a palantine with the earth of the Emperor! walter h, toaae and Maschinenpriester 3 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5725167 Share on other sites More sharing options...
Joukernaut Posted July 31, 2021 Share Posted July 31, 2021 It’s very hard to see whats going on in the picture. Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5725348 Share on other sites More sharing options...
Willy Pete Posted August 3, 2021 Share Posted August 3, 2021 Actually, I like the idea of horses jumping from rooftop to rooftop, sounds very anime like. Cool image. Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5726263 Share on other sites More sharing options...
Beams Posted May 15, 2022 Author Share Posted May 15, 2022 After a huge painting slog, I finally painted up a Paragon Warsuit! RolandTHTG and Bjorn Firewalker 2 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5828043 Share on other sites More sharing options...
Bjorn Firewalker Posted May 15, 2022 Share Posted May 15, 2022 Good job on the model. Beams 1 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5828058 Share on other sites More sharing options...
Beams Posted May 15, 2022 Author Share Posted May 15, 2022 Thanks! Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5828102 Share on other sites More sharing options...
BloodyB Posted May 22, 2022 Share Posted May 22, 2022 Excellent conversion work there, I hadn' noticed the similarites between the Sororitas and the Frankish knights. Now I am going back over my sisters seeing them with a new eye. Honestly, I think just this bit of conversion work is inspiring me to make a small detachment of Zephyrim/Seraphim cavalry, the Order of the Iron Crown, perhaps? Sticks with the Charlemagne theme... Although, considering that Charlemagne was the first Holy (Roman) Emperor, and styled himself and what he built after the Roman Empire, perhaps I should just be calling it '40k themed' instead... Beams 1 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5830708 Share on other sites More sharing options...
Rockybaerboa Posted May 23, 2022 Share Posted May 23, 2022 great idea and fantstic kitbashing. I love your "knights" Beams 1 Back to top Link to comment https://bolterandchainsword.com/topic/370973-beams-crusade-palatine-destroyer-conversion/#findComment-5831159 Share on other sites More sharing options...
