Mk. 4 Land Raider Crusader
Today I managed to aquire a Mk. IV tank of the "female" variant, for roughly €30, pretty cheap compared to GW's LRC.(which is £40 o.0)
I've already noticed that "she" is slightly larger than the standard land raiders.
Now, my question is, how to make one look more like a LRC?
I already bought a Tamiya kit with WWII era US infantry weapons, if that is any help. (Browning M2s are in it, if that matters)
I've also decided to embelish it with a few DA ornaments.
What do you guys think?
https://bolterandchainsword.com/topic/112882-mk-4-land-raider-crusader/
the MKIV female tank was a ww1 era tank, much like an elongated version of the current landraider...here are some pics...
hope this helps to explaint the idea somewhat Onisuzume
http://img.photobucket.com/albums/v634/oldwolf76/MK4F.jpg
http://img.photobucket.com/albums/v634/oldwolf76/MK4E.jpg
http://img.photobucket.com/albums/v634/oldwolf76/MK4d.jpg
http://img.photobucket.com/albums/v634/oldwolf76/MK4C.jpg
http://img.photobucket.com/albums/v634/oldwolf76/MK4A.jpg
Ok, what you will wanna do is start adding rhino/landraider hatches, specifically those w/ a space marine hanging out of them to help tie it in.
Now, you may have to scratchbuild some sponsons for the twin-lascannons as they are pretty wide. You will also need to hull mount a pair of heavy bolters. Getting a hold of some odd land raider parts would actually help you out in tieing it in well. I made a rhino from cereal box card that follows the general shape of the land raider, but is a rhino size. To make this work I had to cannibalize a poor defenseless rhinos details & exhausts. Alot of that comes seperate on the land raider sprues. If you could get a hold of just the sponson weapons & the exhausts & the hatches you'd be set on bits to convert it over but still retain the look of the MKIV.
And IIRC a female was armed w/ only machineguns whereas a male had like 6pdr guns in the sponsons.
ohhhh okay, now i got you ... that kinda looks like the tank that was in the Indiana Jones movie that the nazi's were in ... never knew what it was called ...
would look like to me .. just redoing the side gun mounts with some 'beefier' guns .. and adding a set of hatches behind them ... then a couple of hatches up top and maybe anothe gun or two ... and making up some covers for the top of the tank treads if you wanted to go that far...
hmm might have to look for that model ... been looking around for what it was based on but never came across that one yet.
I'm making a crusader...
And I'm trying to keep it as much in it's original state as possible. (changing the ponsons is kinda impossible now that I've already put them together)
Perhaps a pair of M2s ontop as assault cannon substitutes?
Also, putting a marine next to it is kinda pointless since just about every bit is still on the sprue.(it's about as wide, if it wider than a LR, and at least as long&high)
That was a Mark VIII with a turret added and some more stuff changed — here's a production illustration that shows it quite well.
Wow that's a lovely model Onisuzume.
I think plasticard trackguards along the top would help massivily to bulk it up. All GW Imperial vehicle models look kinda 'clunky' with thick edges to everything whilst this model looks almost delicate. More clunkiness required.
How about the exhaust stack from an LR laid on the top armour plate to visually link it to other SM vehicles. Then items like searchlight, smoke launchers, Imperial Aquila, skulls and suchlike. Oh and Grenade Launchers, might even get away with using those from the LRC mounted horizonatlly onto the angled glacis front plate.
My real question remains - how do marines assault from it - you thinking of putting an assault ramp on the front?
I'm a little worried that many do not recognize one of the most famous tanks in history, what do they NOT teach in schools these days??
other than that sounds like an interesting idea and can't wait to see pics, it has been done many times before, but not for a crusader
The model is at least as big as the GW land raider, so it wouldn't be needed.
And what's plasticard? I've never seen it in the shops...
Well, like I said before, I will be updating the model with a bunch of DA icons like the Angelis Mortis, and, ofcourse, the chapter badge. Smokes and Light is manditory for DA so I'll probably have to get another land raider sprue C.
And who said that I'll use it as a transport?
It's kinda pointless to put 5 storm bolters and 1 CML inside of it.
I'll probably change the gun poking out the front to a twin-linked 1/35 scale M2. (gun devoloped roughly 6-8 years after the tank was built)
Or maybe cannibalise one of the terminator AC arms that I got in my bitzbox. (gattling guns did exist back then, so it could look good)
Also, what would be a good "count as" meltagun?
The tank itself is in in 1/30 brittish scale, so that'd be roughly 1/76 cm for international scale.
it all depends on where you are from ... some areas hardly teach their own history let alone history from other countries ...
that being said, most of what i have learned has came from me reading on my own or from movies and forums etc ... meh .. school was almost pointless when it came to true history.
/endderail
Duh... misread your post sorry. Well then, I dunno what to tell you as changing the sponsons is gonna be pretty neccessary for the hurricane bolters since they are rather large. The M2s should work fine. I suggest trying to at least swap out like the top hatches for rhino/raider hatches for the right look & feel. I've never done a full over conversion from historical to 40K before. The closest I've done is M80 turret w/ TL-lascannons & scratchbuilt sponsons.
You can easily make hurricane bolters out of plastic SM boltguns, but since the sponsons are already built it will be hard to attach them...
Dunno, maybe I'm just not thinking 4th dimensionally :)
Pair of pants to whoever can tell me where that quote came from :)
post a pick with amarine next to it for size comparison.
Can't get a picture untill thursday at least.
Probably not untill a couple of weeks.(mid-august)
Due to lack of access to the model.
Though I might be able to dig up some dimentions.
I think the model is roughly ~7cm high.
The model would be ~28cm long.
A male version would be ~12cm wide.
That is, if my calculations are correct and the model follows those calculations.
So it'd be slightly over two 2nd edition clone marines in height.
the model looks like a pre hersy landraider.
And yeah, that is exactly the look what I'm after, while still largely fitting in with 1910-1930 era tanks.(Yes, I know that the 1st number is off)
So in my posession I have a bunch of 1/35 scale weapons being:
2 browning M2 with tripod, ammo box, ammo belt.
2 Browning M2 without barrel, tripod, Reciever cover.
2 M1919A6 with bipod, ammo box, ammo belt.
2 M3 SMG. (Grease Gun)
4 M1 Rifle. (Garand)
2 M1 rifle with grenade launcher.
2 M18 57mm recoiless gun with tripod.
2 M2 60mm mortar with bipod.
2 flamethrower.
2 M1 carbine.
2 M2 carbine.
2 M1918A2 with bipod. (BAR)
2 2.36" rpcket launcher.
2 M1903A4 rifle. (Springfield)
2 M1A1 SMG. (thomson)
2 flamethrower.
2 M1 carbine.
2 M2 carbine.
Huh, wow. Sounds like they could be fun for use converting IG lol
