Julgolax Posted August 17, 2007 Share Posted August 17, 2007 Just out of curiosity, what conversion(s) have you seen in Space Marines and Chaos Space Marines that stands out as the best, the most inventive, the most artistically advanced, even the most outlandish. My personal experiences have led me to see many different conversions good and some bad. One of my favorites that I have seen would have to be a Warsmith of the Iron Warriors Legion. This particular warsmith was a very interesting piece of work. The creator used an ingenious way of converting a techmarine in full Servo-arm harness into a Warsmith with a Defiler base. He cut the techmarines lower legs and feet off and attached that to the connector joint of a defiler's leg plate. He then replaced the joint, forearm, and claws of the 2 from limbs of the defiler with twin stormbolter turrets. IF that isnt cool I dont know what is... :) too bad it is illegal in game terms... :teehee:. So, what have you seen? Has no one ever seen a conversion that really hit them as unique, cool, odd, intersting? Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/ Share on other sites More sharing options...
battle captain corpus Posted August 19, 2007 Share Posted August 19, 2007 There is an excellent brother on this site who creates some of the most perfect Nurgle tanks I have ever in all my 17 years of GW collecting seen. For the life of me I cannot remember the threads/brothers name. His work is inspired, using masses of milliput, GS, random tubing and so forth to create some truly sickening vile filth (this is meant in the best possible compliment!) :P Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337011 Share on other sites More sharing options...
Tomathus The Mighty Posted August 19, 2007 Share Posted August 19, 2007 Im new 2 this forum but here goes... i saw on the GW website a while back a pic of an unpainted librarian modelled 2 b using a psychic power. Wat this guy did was model a pair of flaming skulls twisting around the librarians outstrecthed arm. Blevive me, it looked amazing. :P and btw can some1 plz tell me how 2 post pics :D Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337028 Share on other sites More sharing options...
battle captain corpus Posted August 19, 2007 Share Posted August 19, 2007 i saw on the GW website a while back a pic of an unpainted librarian modelled 2 b using a psychic power. Wat this guy did was model a pair of flaming skulls twisting around the librarians outstrecthed arm. Blevive me, it looked amazing. and btw can some1 plz tell me how 2 post pics That was I think a conversion of Tigerius, the Ultras Libby aka "Tigger"! :P Was a nice piece of work! Welcome to the B&C brother! Just as a tip, spend an extra couple of seconds to type out your posts fully, text speak can lead to people lambasting you, trust me on this! :D Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337071 Share on other sites More sharing options...
Spacefrisian Posted August 19, 2007 Share Posted August 19, 2007 Here is mine (wich gets a lot of attention every time i take it with me.) http://i34.photobucket.com/albums/d109/Spacefrisian/Spacewolves/IMG_1273.jpg (Don't know if you would like to get an explanation so i just add one) The following were used: Plastic Dreadnought Pair of Penitant (PE) engine legs Fenrisian wolfhead or Juggernaut of Khorne head Tau Battlesuit feet Various bits (whichever you like ading) Assemble the main body of the dread but do not add plate and exhaust to it. Cut the legs (keept the underlegs intact they'll be needed)in order to get the PE Legs fitted to it (takes some GS) Assemble the front legs by taking the upper arm and combining them with the leg parts to extend them somewhat. Try to get the right pose as you put it together and finish this by adding the Tau feet and the Dreadnought feet to it. When it has stabilised (GS has dried enough) add the Exhausts/ Weapons/ head(s) etc to it and it should be done. Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337075 Share on other sites More sharing options...
Rymeer Posted August 19, 2007 Share Posted August 19, 2007 Here is mine (wich gets a lot of attention every time i take it with me.) http://i34.photobucket.com/albums/d109/Spacefrisian/Spacewolves/IMG_1273.jpg (Don't know if you would like to get an explanation so i just add one) The following were used: Plastic Dreadnought Pair of Penitant (PE) engine legs Fenrisian wolfhead or Juggernaut of Khorne head Tau Battlesuit feet Various bits (whichever you like ading) Assemble the main body of the dread but do not add plate and exhaust to it. Cut the legs (keept the underlegs intact they'll be needed)in order to get the PE Legs fitted to it (takes some GS) Assemble the front legs by taking the upper arm and combining them with the leg parts to extend them somewhat. Try to get the right pose as you put it together and finish this by adding the Tau feet and the Dreadnought feet to it. When it has stabilised (GS has dried enough) add the Exhausts/ Weapons/ head(s) etc to it and it should be done. Lovely conversion, but you missed a bet there in my opinion. The use of an additional pair of Sentinel Legs, or perhaps even the arms from the new TechMarine's ServoHarness, with attached DCCW fists with longer 'claws', would make this look nastier. Mounting points would be either side of the AC, on the flat space above the vertical surface you placed the dread's name. I dunno about you, but a four footed, walking steel wolf-tank, with weapons and CCW arms would scare me! Just a thought, Rymeer Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337127 Share on other sites More sharing options...
Rymeer Posted August 19, 2007 Share Posted August 19, 2007 Oh, yeah... I should post a conversion too... okay.... converted Damocles Command Rhino (sorry for the bad pics) Damocles damocles Left Damocles Right Damocles Interior And just for fun.. the Land Speeder 'Limo' for dropping a whole 10-man squad of assault marines into combat. LS Limo Front LS Limo Left LS Limo Right LS Limo Back LS Limo Underside Ok, enough from me Rymeer Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337147 Share on other sites More sharing options...
The Rubberduck Posted August 19, 2007 Share Posted August 19, 2007 Probably this one. http://i184.photobucket.com/albums/x94/rockarn91/My%20Ultras/PICT0850.jpg Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337602 Share on other sites More sharing options...
grimtuff Posted August 19, 2007 Share Posted August 19, 2007 Here is mine (wich gets a lot of attention every time i take it with me.) http://i34.photobucket.com/albums/d109/Spacefrisian/Spacewolves/IMG_1273.jpg Looks mighty familiar does that.... :teehee: http://img.photobucket.com/albums/v615/Grimtuff/Space%20Wolves/Dognought.jpg Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337614 Share on other sites More sharing options...
divineauthority Posted August 19, 2007 Share Posted August 19, 2007 The wolfy one reminds me of something out of Power Rangers, the old 90's ones. I think the blue ranger had a big wolfy thing http://uk.geocities.com/darth_jurious/zords/wolfzord.jpg Terrible pic really....... Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1337742 Share on other sites More sharing options...
Grimdarkness Posted August 20, 2007 Share Posted August 20, 2007 I played a guy who had gone all out on his 40K in 40 Minutes raven gaurd army. He had marines with garrot wire and knifes in the teeth and his boss had a imp gaurd officer hanging of his combat knife about a foot of the ground. Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1338253 Share on other sites More sharing options...
Spacefrisian Posted August 20, 2007 Share Posted August 20, 2007 Yeah i was inspired by the PR Ninjazord wolf and the Freads on Coolminiornot. (their were more of them their along with a dinoversion for Salamanders) Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1338340 Share on other sites More sharing options...
BobPanda Posted August 20, 2007 Share Posted August 20, 2007 inspired in october 2005 by acechante nocturnos thread in the wip-forum: ==>> link to acechante nocturnos thread in wip-forum <<== - and espacialy by his great idea of building a wolfdread (and several other ones: dino, gorilla ... ) i started building my own one in early december 2005 as well. here's a link to cmon, where you can find my source of inspiration: wolfdread - http://i179.photobucket.com/albums/w313/BobPanda/wolfcybot_lord/DSCN0738.jpg http://i179.photobucket.com/albums/w313/BobPanda/wolfcybot_lord/DSCN0730.jpg http://i179.photobucket.com/albums/w313/BobPanda/wolfcybot_lord/DSCN0734.jpg http://i179.photobucket.com/albums/w313/BobPanda/wolfcybot_lord/DSCN0733.jpg - Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1338399 Share on other sites More sharing options...
Wolfside Posted August 21, 2007 Share Posted August 21, 2007 man thats pretty mental Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1338820 Share on other sites More sharing options...
Stella Cadente Posted August 21, 2007 Share Posted August 21, 2007 Oh, yeah... I should post a conversion too... okay.... converted Damocles Command Rhino (sorry for the bad pics) Damocles damocles Left Damocles Right Damocles Interior And just for fun.. the Land Speeder 'Limo' for dropping a whole 10-man squad of assault marines into combat. LS Limo Front LS Limo Left LS Limo Right LS Limo Back LS Limo Underside Ok, enough from me Rymeer do you have these in NONE Yahoo Flikr (or whatever) format? cus theres no way of seeing them, everytime I sign in it takes me to a blank page ;) Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1338827 Share on other sites More sharing options...
Dragoonman Posted August 21, 2007 Share Posted August 21, 2007 Hmm.... this is a tough question. As far as my favorite piece o' work is, I'd have to go with a single army. I can't remember where I found it online, and I don't seem to have any photos, but this guy had done a Scythes of the Emperor army, which consisted of the suriviors of the decimation of that chapter. Each model was posed and converted to be fighting 'nids, with each squad fighting a different breed, or under different circumstances. I loved it because the actions poses were perfect, capturing the fighting style adn the movement of the combatants, and it even inspired me to do a few like it, although they will never rival the sight of all those black and yellow marines on a scenic base. Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1338855 Share on other sites More sharing options...
SkullBob Posted August 21, 2007 Share Posted August 21, 2007 inspired in october 2005 by acechante nocturnos thread in the wip-forum:==>> link to acechante nocturnos thread in wip-forum <<== - and espacialy by his great idea of building a wolfdread (and several other ones: dino, gorilla ... ) i started building my own one in early december 2005 as well. here's a link to cmon, where you can find my source of inspiration: wolfdread - http://i179.photobucket.com/albums/w313/BobPanda/wolfcybot_lord/DSCN0738.jpg http://i179.photobucket.com/albums/w313/BobPanda/wolfcybot_lord/DSCN0730.jpg http://i179.photobucket.com/albums/w313/BobPanda/wolfcybot_lord/DSCN0734.jpg http://i179.photobucket.com/albums/w313/BobPanda/wolfcybot_lord/DSCN0733.jpg - This one is one of my favorites. I have started building my own based on BobPanda's hopefully it will turn out half as nice. Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1338908 Share on other sites More sharing options...
Hakashi Posted August 21, 2007 Share Posted August 21, 2007 :rolleyes: hehehe, I love the idea of a 4 legged wolf dread..... one of my firneds have been a wolf player for years and I shocked neiother him nor myself have thought of that! Cool stuff! I'll try and get off my lazy butt and post my WIP chaos Lord..... -Hak- Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1339708 Share on other sites More sharing options...
Driseamail Posted August 21, 2007 Share Posted August 21, 2007 This is my latest dread, still working on the base of it as well as final touch ups, but I'm quite pleased with it overall. That said, it's nowhere near as cool as some of the dreads that have already been posted. http://i53.photobucket.com/albums/g60/Driseamail/40k/dread.gif Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1339753 Share on other sites More sharing options...
Beef Posted August 22, 2007 Share Posted August 22, 2007 my SW VEN DRED and my true scale preditor tanks whick will now be used as baneblades in apoc as they are the right size http://i59.photobucket.com/albums/g320/vittorio_13/bestarmy006.jpg http://i59.photobucket.com/albums/g320/vittorio_13/shyswed004.jpg Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1340505 Share on other sites More sharing options...
Dark Bjoern Posted August 22, 2007 Share Posted August 22, 2007 I think this will be my favorite conversions. The LRC i´ve made as a driveable relic shrine for my Grey Knights. http://i186.photobucket.com/albums/x120/DarkBjoern/Grey%20Knights/GreyKnightCrusaderLandRaiderleftsid.jpg http://i186.photobucket.com/albums/x120/DarkBjoern/Grey%20Knights/GreyKnightCrusaderLandRaiderfront.jpg And my Rune Lord Thorgrimm Stormclaw and his retinue http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/Runelordrightside.jpg http://i186.photobucket.com/albums/x120/DarkBjoern/Space%20Wolves/RunelordandRetinue1.jpg Not that spectacular like the work from BobPanda and spacefrisian, but i like them. BobPanda your works are great. And hey Driseamail cool idea to mix up a dread with a sentinal. Dark Bjoern Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1340522 Share on other sites More sharing options...
grimtuff Posted August 22, 2007 Share Posted August 22, 2007 Beef: Repeat after me. PredAtor PredAtor PredAtor Nice tanks though..... Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1340566 Share on other sites More sharing options...
Brother Jobu Posted August 22, 2007 Share Posted August 22, 2007 This is my latest dread, still working on the base of it as well as final touch ups, but I'm quite pleased with it overall. That said, it's nowhere near as cool as some of the dreads that have already been posted. Kind of reminiscent of the old ED 209. Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1340569 Share on other sites More sharing options...
Beef Posted August 22, 2007 Share Posted August 22, 2007 Beef: Repeat after me. PredAtor PredAtor PredAtor Nice tanks though..... Its now Beneblade lol Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1340664 Share on other sites More sharing options...
Cygnwulf Posted August 23, 2007 Share Posted August 23, 2007 I'm currently in the process of converting a Dread with variable geometry legs. 'dual mode' for tracked movement or walker movement. If anyone's ever seen any of the walker/tank minis from the game 'Gear Krieg' that's kind of what I'm working on. I'm scratch building some tank tracks and housing attachments on and around a pair of sentinal legs. Link to comment https://bolterandchainsword.com/topic/116052-what-are-your-best-conversions-and-ideas-for-them/#findComment-1340839 Share on other sites More sharing options...
