Preheresy Raven Guard
Corvinvs
Hello Alls!
I would like to present for you my completed first tactical squad of my pre-heresy style Raven Guard Army.
Two a little bit different view of my completed unit
http://legio-x.ru/ts/40k/ph_sm_rg_1st_tac_sq_2.jpg
http://legio-x.ru/ts/40k/ph_sm_rg_1st_tac_sq_3.jpg
https://bolterandchainsword.com/topic/120699-preheresy-raven-guard/
Well done, I especially like the use of gold. I also like the PH appearence, I mean, that they are not the same, every marine looks personalized (that is what I like the most about the PH marines :FA: )
What about the chapter symbol ? decals or freehand ?
Again, excellent & :P work !
Cpt Stahl.
yeah where'd you get all the preheresy armour? and bolters? looks awesome.
If I'm not mistaken, the armour comes from the Forge World Red Scorpians conversion set.
The bolters would easily be acquired through bitz, as you can order the Space Marine Backpack Accessory Sprue (99399999031) from the classic range still.
OK, thanks all for your praise.
I try to answer for some questions:
1. Unfortunately my English isn't perfect from readable and usable tutorial :( I can only post some close-up pics of separate figures and some WIP pics.
2. Bolters are mix: some are modified standart bolters from modern SM-sprue, and some are green-stuff coppy of bolter from SM-biker sprue.
3. Only one helmet is from BT-spue, other all are created from standart helmets from SM-sprue + geen-stuff.
4. All torsos are from SM-sprue + geen-stuff, all legs too.
5. Pins are either very small balls from green-stuff, or "heads" of tailor's nails.
6. Raven on shoulder-pad is freehand.
7. Backpacks are modified from standart BP from modern SM-sprue.
And now some close up and WIP pictures:
Sergeant (in future simple veteran):
http://legio-x.ru/ts/40k/preheresy-sm-wip-1.jpg
http://legio-x.ru/ts/40k/preheresy-rg-sgt-1.jpg
Two different SMs in Mark V
http://legio-x.ru/ts/40k/preh-sm-mk3-wip1.jpg
http://legio-x.ru/ts/40k/preh-sm-mk3-wip2-bt1.jpg
http://legio-x.ru/ts/40k/sm-preh-mk5-fin.jpg
http://legio-x.ru/ts/40k/sm-preh-mk5-bt-2-fin.jpg
Two different SMs in Mark III
http://legio-x.ru/ts/40k/sm-preh-mk3-bt-1-fin.jpg
http://legio-x.ru/ts/40k/sm-w-ml-pa-m3-wip.jpg
http://legio-x.ru/ts/40k/sm-preh-mk3-ml-1-fin.jpg
SM in Mark IV
http://legio-x.ru/ts/40k/sm-preh-mk4-1-fin.jpg
I hope thet my answers will be a little bit helpfull :)
1. Unfortunately my English isn't perfect from readable and usable tutorial :) I can only post some close-up pics of separate figures and some WIP pics.
Thank your for the pictures and accompanying explanations. Your work is incredible!
Also, as an English teacher at the upper secondary school level, let me assure you that your English, while not perfect, is perfectly intelligible. We can understand you just fine. :-)
