BillyBob Posted November 19, 2007 Share Posted November 19, 2007 I did this for my Razorbacks for my GT army. Just figured I should share what I learned in regards of how to do this.. Because it makes games somewhat more interesting. To be honest, it's really more simple than you think, so long as you can deal with the rear ramp sometimes falling down.. but heck, you're making a vehicle that turns into wreckage! You should paint the inside anyway!!! Before you do this, make sure ALL flash and clippings are filed as flat as they can be. To begin, you need the following: http://img.photobucket.com/albums/v433/NillyBob219/DSCN2748.jpg 1: Two completely assembled sides from a rhino chassis (wheter they be predator, rhono/razorback or even the new vindicator plastic kit, doesn't matter) 2: Floor/bottom hull 3: Front plate/windshield (Or vindicator cannon) 4: Top hatch/ vindicator plate/ turret mount (pick applicable) 5: Rhino top 6: Interior bitz (Yes, you REALLY need this bit) 7: rear ramp OKay, so now that we have that straight, take one built side of the chassis and slide the floor in place and put the ramp peg in the side. Hold them in place like so: http://img.photobucket.com/albums/v433/NillyBob219/DSCN2749.jpg Now slide the other side in place, aligning everything. Once everything fits in place, slide the interior bit in. This bit helps to keep rigidity in the hull despite it not being glued together. Also, it becomes thicker once primed and painted, thus fitting even more snugly and adds more support. so, you should be here: http://img.photobucket.com/albums/v433/NillyBob219/DSCN2750.jpg Now, slide the top onto the chassis. THe interior should be able to hold the model together while you do this. if not, hold the chassis by the sides and use yoru other hand to slide the top on. It's the only true snap in peice. http://img.photobucket.com/albums/v433/NillyBob219/DSCN2751.jpg To check that the top is in properly.. besides the fact that the model isn't falling apart, check by where the front of the hull goes.. which is now a gaping hole. http://img.photobucket.com/albums/v433/NillyBob219/DSCN2752.jpg Once the hull is secured, slide the front in as so: http://img.photobucket.com/albums/v433/NillyBob219/DSCN2753.jpg Add the top hatch/plate/turret mount and you're done! http://img.photobucket.com/albums/v433/NillyBob219/DSCN2754.jpg As some of you can see, the model I used is going to be a destroyable vindicator. here it is all done: http://img.photobucket.com/albums/v433/NillyBob219/DSCN2755.jpg and blown up: http://img.photobucket.com/albums/v433/NillyBob219/DSCN2756.jpg the only issue with the vindi is that it's front heavy. So the front tends to want to fall off. however after I added the dozer blade, it was more well behaved. I am debating on using magnets on the top and front to secure it, as it is a bit more tempermental than a normal rhino chassis. I'll post more if it comes to that. Anyway, enjoy this tutorial and use it well! Link to comment https://bolterandchainsword.com/topic/123604-modelling-how-to-make-a-rhino-chassis-destructable/ Share on other sites More sharing options...
darkmarauder Posted November 19, 2007 Share Posted November 19, 2007 Nice one. Link to comment https://bolterandchainsword.com/topic/123604-modelling-how-to-make-a-rhino-chassis-destructable/#findComment-1423989 Share on other sites More sharing options...
Shaun Carlin Posted November 21, 2007 Share Posted November 21, 2007 Wow i did that too to make my tanks easier to transport around. I thought i was the only one. :) Link to comment https://bolterandchainsword.com/topic/123604-modelling-how-to-make-a-rhino-chassis-destructable/#findComment-1425184 Share on other sites More sharing options...
