Chaos Speeders
RocknChaos
Like you said, there is no reason fluff-wise.
Other then perhaps they're more modern, ie. Post-Heresy only, and those stolen were unoperable due to some sort of protection.
Then again there's not much the Dark Adeptus cant convert to chaos machine wise.
Perhaps the chaos gods simply hate floating cars? My weirder idea :P !
If you DID find rules, then you could most likely convert one easily with chaos vehicle fram bitz, and perhaps even a mutated one, like:
Tzeentch: Winged or HUGE magical flame firing boosters (think the Flamers of Tzeentch but BIGGA!)
Nurgle: A giant slug-like one, or maybe even one that stays aloft like a hovercraft with putrid gas. :P !
Slaanesh: A sorta spider-thing, or perhaps one pulled by Steeds of Slaanesh.
Khorne: Its grown mechanical LEGS! Lol! Or more seriously, maybe its boosters fire it along like a fire hose, only with BLOOD not water!
Just my 2 cents hehe ;)
You mean something like that? A friend made them and uses him with the VDR.
http://i186.photobucket.com/albums/x120/DarkBjoern/Renes%20Chaos%20Forces/Bild001.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Renes%20Chaos%20Forces/Bild008.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Renes%20Chaos%20Forces/Bild006.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Renes%20Chaos%20Forces/Bild004.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Renes%20Chaos%20Forces/Bild003.jpg
http://i186.photobucket.com/albums/x120/DarkBjoern/Renes%20Chaos%20Forces/Bild002.jpg
Well thanks to Apocalypse you can just take Land Speeders from the Space Marine codex. The reason for 'enemies' to be allies? Just renegade Land Speeders, or possibly the Chaos army only recently turned renegade and therefore has access to newer stuff. My Apocalypse force combines choices from the Space Marine and Chaos Marine lists. Apocalypse would let you take anything after all, if you can come up with a reason.
Just say that daemonstones that induce anti-gravity are installed on your possessed ships.
As for VDR, I'll just throw something up right now as en example of its cost. Usually its wise to just use one for a while until your group accepts that they are fair, (or rather unfair for you because its spendy points-wise) and then you could use more, or stop at just 1.
Fast Attack (80vehicle+45weapons)
Hellspander: 125 Points
10/10/10 BS4
Skimmer, Enclosed, Fast, Small Light Vehicle
Inferno Cannon, Melta Gun
Its pretty much a skimmer-hellhound, about as durable because of the fast+skimmer combo, and it has 24" range so it can munch medium/light troops as well or better then an assault cannon, added in a meltagun in there for a secondary weapon since it would fit the heat-theme, and not a multi-melta because ammo storage for the Inferno Cannon requires a lot of space.
Simple example. I saw some plans for a 3 spot mortar launching open topped one a while back, I tried it and it was pretty nice but they called it cheese so I didnt go through making it. Apparently a fast skimmer with 3 mortars on it is a little too hard to pin down to shoot. So be careful when you design something, keep the spirit of being equal in mind, and dont go making a 3 assault cannon beast.
  • 2 months later...
