pott Posted April 5, 2008 Share Posted April 5, 2008 It's dead easy... I cut out the barrel and front of the bolter, as well as the handle, sight and mag. The barrel is put where the mag was as a plasma mag. I also cut the bolt. The slit is still there but ah well. Then cut the front of the plasma pistol , file it flat and it goes in front of the bolter. Cut out the hand together with the mags and wee assembly. Flatten this area under the bolter and glue. Tada. I did that because I have loads of spare plasma pistols and bolter, but not a single plasma gun. Dunno what the new tactical squads come in so for all I know it may be a pretty silly thing to do now but for those like me who have spares and little money for special weapons, it's a cool little mod. Most likely been thought before, who knows. I'm working on pictures. EDIT: with this the grip is slightly forward so you may need your marine to hold it with one hand only. And for IGs, you just cut the handle and glue it on their hands. Pics (crap camera can't focus this close...) http://i7.photobucket.com/albums/y300/PierreEmmanuel/DSC00568.jpg http://i7.photobucket.com/albums/y300/PierreEmmanuel/DSC00569.jpg http://i7.photobucket.com/albums/y300/PierreEmmanuel/DSC00570.jpg Link to comment https://bolterandchainsword.com/topic/133342-modelling-converting-a-bolter-into-a-plasmagun/ Share on other sites More sharing options...
TeamLando Posted April 5, 2008 Share Posted April 5, 2008 Sweet! I wonder If this could be applied in the same way x2 if you're trying to do a Plasma Cannon o.o Link to comment https://bolterandchainsword.com/topic/133342-modelling-converting-a-bolter-into-a-plasmagun/#findComment-1536561 Share on other sites More sharing options...
pott Posted April 6, 2008 Author Share Posted April 6, 2008 I doubt it would, the PC is a real big and quite complex weapon... dunno. Try it! Link to comment https://bolterandchainsword.com/topic/133342-modelling-converting-a-bolter-into-a-plasmagun/#findComment-1537452 Share on other sites More sharing options...
teh_perfesser Posted April 8, 2008 Share Posted April 8, 2008 You can never have enough plasma guns. If you don't get a better camera before I get some loyalist marine parts, I'm totally scooping this :rolleyes: (P.S.: I just found the parts in a box of Devastators... now that I have a good look at them, I'd probably keep the ridge parts of the plasma pistol, cut it down like a L shape...) Link to comment https://bolterandchainsword.com/topic/133342-modelling-converting-a-bolter-into-a-plasmagun/#findComment-1538425 Share on other sites More sharing options...
TeamLando Posted April 8, 2008 Share Posted April 8, 2008 I doubt it would, the PC is a real big and quite complex weapon... dunno. Try it! Yeah, I doubt it too, but looking at my Long Fang's Plasma cannon, I kinda see a way ... I might be able to pull it of, but I'd havce to use greenstuff and plastic ... hm, hm. A plasmagun hiwevere, shoukd be easier to work with. Link to comment https://bolterandchainsword.com/topic/133342-modelling-converting-a-bolter-into-a-plasmagun/#findComment-1538816 Share on other sites More sharing options...
Gareque Posted April 9, 2008 Share Posted April 9, 2008 Sweet! I wonder If this could be applied in the same way x2 if you're trying to do a Plasma Cannon o.o Not for a plasma cannon, but i guess if your opponents kind enough it could be used to make a twinlinked plasma gun :D Link to comment https://bolterandchainsword.com/topic/133342-modelling-converting-a-bolter-into-a-plasmagun/#findComment-1539902 Share on other sites More sharing options...
SeanyPrawny Posted April 10, 2008 Share Posted April 10, 2008 I had to make a plasma gunthis way for my guys, damn lousy GW only providing me with a melta gun. Looks good though with the plasma pistol barrel and the 'core' part placed carefully into a place cut from the bolt ejector bit thing after i cut it out. Great guide even if a little bit late for me lol. Link to comment https://bolterandchainsword.com/topic/133342-modelling-converting-a-bolter-into-a-plasmagun/#findComment-1540192 Share on other sites More sharing options...
