Okay, 2 DPs Tzeentch, Warp Time, Bolt of Change, 1 GGD is half your points.
The other half is composed of:
2 X 5-man T-Sons with AS ea with Bolt of Change.
1 5-man Chosen with AC with HB (not the AC as he will be the GGD host)
The thing with this is that it'll knock out any MCs silly, but what to do with the advancing genestealers. They'll no doubt be going through cover which will make your AP3 weaponry a mute point and your T-sons redundantly expensive.
A better list would be:
Two Tzeentch Dps both with doombolts, 1 with Warp Time ^_^ 1 with Bolt of Change
1 GGD
1 5-man Chosen incl AC with flamer and HB with Icon
2 5-man CSM incl AC with flamers one with PF (if you can squeeze it in) both with Summoning Icons
2 6-man SLD (these little critters will tar pit genestealers with their 5+ inv saves)
The last list is not entirely T-sons but it'll be more effective in a 1000 point environment.
Cheers,
My take on this idea would be to keep the princes cheap, besides its a 1k game theres not going to be THAT much on the other side of the board.
H.Q. 360
Prince w/ wings- 130
Greater Daemon- 100
Elite 140
4x Termies all w/ Combi-Plas- 140
Troop 500
10x CSM in a rhino. 2x Melta, IoCG, Champ w/ combi-plas. - 255
10x CSM in a rhino. 2x Flamers, IoCG, Champ w/ combi-plas. - 245
The Termies are a matter of taste, you could easily replace them with a tank, 10 lesser daemons, or two oblits if you play with the points just a little. That the list I would run at a 1000 points if I wanted to be slapped though.
Tyrannids codex is the most broken. You'll be hard pressed placing 3 Chaos MCs in under 1000. Try 2 DP Tzeentch, with Warp Time rerolling all misses :) and two 5-man Chosen with aspiring and heck, I'll make you a list with army builder, just a sec.
I don't think it's really broken, just the old chaos codex wasn't broken.. there's only some room for abuse of some things in it.
Nidzilla's, I god nids too and take 5 in 1.5k (all 3+ save)..
If it's similair the nidzilla's you face, you can take some squads with AP2 weaponry.
And 2DP's with warptime.. a GD is not that great IMO. maybe to do some carnifex hunting..
I've been putting something together myself as well. Its basicly a CSM version of the new Deamon codex that is to come. (quite funny)
HQ:
DP:
-Wings, mark of Tzeentch, warptime
DP:
-Wings, mark of Tzeentch, Warptime,
Greater Deamon
Troops:
CSM: x5
-ASP: powerfist
-melta, icon of chaos
CSM: x5
-ASP: powerfist
-meltagun, icon of chaos
Lesser Deamons: x10
Heavy:
Defiler:
-Add ccw for flamer
1000 points
24 models
Not many models but than again it also works with Nids
