I just got some stuff in from GW today which I am converting into a DP and I was wondering what size of base do they use??
the monsterous creature sized base or the termie sized one?
or does it even matter? b/c the Undivided DP on the GW site looks like it has a termie sized base and the nurgle DP looks like it has a monsterous creature sized base.....
Thanks in advanced for any help
L.G.D.
https://bolterandchainsword.com/topic/134343-dp/
the undivided prince comes with a 40mm base (termies). i'm not sure what comes with the nurgle prince but the minimum size is 40mm.
you can put it on a larger base but the base can't be smaller than the one it comes with. so you can put your prince on a 60mm base or a 40mm base but none smaller than 40mm.
https://bolterandchainsword.com/topic/134343-dp/#findComment-1546599
Rules-wise? 40mm base or larger, as mentioned above.
However, I strongly reccomend at least a 60mm base for any monsterous creature. It's bound to be a large impressive model, it deserves a large, impressive base. models with feet hanging off their bases never look good, and chances are you'll want the wider base for stability, anyway.
https://bolterandchainsword.com/topic/134343-dp/#findComment-1549693
  • 2 weeks later...
