well, thousand sons were a result of the rubric of Ahriman. Pretty much anyone with little or no psychic powers were turned to dust in their power armour.
Berserkers are pretty much lobotomised marines. IIRC parts of the brain which control pain and rational thinking is removed.
Acctually, i think loss of rational thinking may be a side effect of the lobotomy.
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1546572
They are the Thousand Sons Chapter Marines. The Thousand Sons were affected by wide spread mutation. To stop it from spreading further in the legion Ahriman cast his now infamous Rubric. All rubric Marines were once normal Thousand Sons Marines although now they are mindless automatons.
While Beserkers, Noise Marines and Plague Marines appear outside the World Eaters, Emporors Children and Death Guard there is no canon fluff i know of to support Rubric Marines outside the Thousand Sons Chapter, not to say you can make some up
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1546633
The Thousand Sons is the name of the original legion.
Quick breakdown:
World Eaters = Khorne Berzerkers
Emperor's Children = Noise Marines
Death Guard = Plague Marines
Thousand Sons = Thousand Sons
as stated several time here and in other places - you are wrong
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1547121
Quick breakdown:
How so? The OP wanted a quick guide as to which of the original legions provided the majority of the original 'cult' troopers, and Peredyne provided it. Do you have info that contradicts this? A flat 'you are wrong' is aggressively unhelpful, particularly when the poster you are jumping on is right as per the parameters of the original question.
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1547239
Quick breakdown:
You're right flintlocklaser, saying that Peredyne is 'wrong', is indeed a bit blunt. But Night Stalker does have a point. It is not really wrong, but a it's not accurate either.
Saying that cult-troops (berzerkers and the like) come from the four original legions is technically correct, but it's a gross simplification. The Black Legion has World Eater psycho-surgeons that can replicate the original implant and make 'true' berzerkers instead of simple frenzied Khorne worshippers. Like wise the Nurgle Sorcerors can gift other Chaos Marines with the Destroyer Plague that turns them into Plague Marines. Noise Marines are just Slaaneshi warriors with sonic weaponry, any Slaanesh worshipping Marine with a sonic blaster is automatically a Noise Marine no matter his origins.
It's true that these four legions consist almost exclusively of Cult troops, but cult troops do not automatically come from these legions. Except of course Rubric Marines, those are 1k sons only warriors, but I've heard stuff about new ones being made. Not sure 'bout those though. Codex-fluff states pretty clearly that only the warriors present on the Planet of Sorcerors during the casting were turned into Rubric warrior automatons.
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1547262
But again, the OP asked for a simplified answer, which Peredyne correctly (as you said) provided. Then, your expanded answer also addressed the OP's follow-up question about how Abbadon came to field cult troops despite not being from their original legions, which was both helpful and correct. A flat and unsupported 'you are wrong' however, is worse than useless, it's combative and uninformative.
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1547281
Now, With Abbadon's black crusades, was there not warriors of all four variaties? was this just an alliance of multiple armies or did he have such resources in his personal army?
Yes, there was warriors of all 4 variates.
Yes, it was an alliance of multiple armies and legions.
Yes, there is also warriors of all four "cult" types in the Black Legion, Abbadon's "personal" army.
BL brzrkrs that are not worldeaters, BL "noisemarines" that are not E' children, etc.
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1547343
Essentially, all squares are rectangles, but not all rectangles are squares. AFAIK, the same goes for cult marines, i.e. all Death Guard are Plague Marines, all World Eaters are Khorne Berzerkers, not 100% on the Emperor's Children, but, all Thousand Sons (the legion) are Thousand Sons (the cult marines). However, not all Plague Marines are Death Guard, etc. Not 100% on this, someone correct me if I'm mistaken, or confirm so I don't feel like an idiot :pinch:
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1547408
The Thousand Sons, unlike the other Chaos Space Marine "cults" (Plague Marines, Khorne Berserkers) are all derived from the legion of the same name. They were the result of the legion's chief librarian's attempts to halt the physical degeneration that exposure to Chaos was causing following their fall into the service of the Chaos God Tzeentch. The Khorne Berserkers are a cult that originally derived from the World Eaters legion, and are utterly dedicated to their role as the Sacred Destroyers of the Blood God. They are joined by initiates from various other sources, and are by and large the most expansive and significant of the Traitor Marine "cults".
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1547913
Essentially, all squares are rectangles, but not all rectangles are squares. AFAIK, the same goes for cult marines, i.e. all Death Guard are Plague Marines, all World Eaters are Khorne Berzerkers, not 100% on the Emperor's Children, but, all Thousand Sons (the legion) are Thousand Sons (the cult marines). However, not all Plague Marines are Death Guard, etc. Not 100% on this, someone correct me if I'm mistaken, or confirm so I don't feel like an idiot :P
You got it pretty much. The only part that is different is the Thousand Sons as mentioned already.
TDA
https://bolterandchainsword.com/topic/134344-chaos-legions/#findComment-1548666
