Homegrown Codex: Iron Warriors
Eversince I got into chaos I liked 2 armies World Eaters + Iron Warriors as I was new I opted for WE as they seemed the easier choice. Now I've started an IW force but Codex: CSM just doesn't work for IW I thought i'd take a wack at my own home grown codex.
Here goes:
HQ
Warsmith – 90pts
5 6 4 4 3 5 3 9 3+
Equipment
Power armour, Bolt pistol, Boltgun, CCW, Frags, Kracks, Bionics
Special rules:
Fearless, Independent character, 5+ Inv save,
Options:
May take Mark the Dark Mechanicus for 15pts
May take 1 Servo Arm for 30pts or a Servo Harness for 75pts
May replace bolt pistol with plasma pistol for 15pts
May replace CCW with:
power weapon for 15pts
power fist for 25pts
single lightning claw for 25pts
two lightning claws for 30pts
master crafted power weapon 30pts
May take one of the following:
Twin-Linked bolter for 5pts
Combi-Weapon for 10pts
May take Melta-Bombs for 5pts
Jump Pack for 20pts
Bike for 30pts
Arch Obliterator – 100pts
4 5 4 4 2 4 2 9 2+
Wargear:
Single Chain-Fist
Oblit-Weapons:
(one per turn from lascannon, multi-melta, Plasma Cannon, Twin-Linked plasma gun, twin-linked melta-gun or a
Heavy Bolter)
Bionics
Special Rules:
Fearless
4+ inv save
Slow and Purposeful
Deepstrike
Option:
May take Mark of the Dark Mechanicus for 15pts
Cyber prince - 160pts
7 5 6 5 4 5 4 9 3+
Wargear:
Kai gun, Power fist, Cybernetics
Special Rules:
Fearless
Inv Save 5+
Eternal Warrior
Options:
Anti-Grav Pack/Mechanical Wings for 20pts
Elites
0-1 Obliterators (see chaos codex)
Chosen (see chaos codex)
Cyborgs 26pts per man (squad size 5-10)
4 5 4 4 1 4 1 9 3+
Cyber champion +10pts
4 5 4 4 1 4 2 9 3+
He may take a single Servo Arm for 30pts
Wargear: power armour, Boltgun
Options:
Two models may replace their bolters with one each of the following
Heavy bolter for 15pts,
missile launcher for 20pts,
auto cannon for 20pts,
lascannon for 35pts,
Troops
Iron Warriors 15pts per man (5-20 men in a squad)
4 4 4 4 1 4 1 8 3+
Aspiring champion +15pts
4 4 4 4 1 4 2 9 3+
Wargear:
Boltgun, Power armour
Options:
Champ may replace bolter with the following: Twin-Linked Bolter for 5pts, Combi-Weapon for 10pts, Power
Weapon and Plasma pistol for 30pts or Power Fist and Plasma pistol for 40pts
He may take meltabombs for 5pts
He may take Terminator Armour w/ Chain-Fist and Twin-Linked Bolter for 35pts
One Iron Warrior may replace his Bolter with one of the following:
Plasma Gun for 15pts, Meltagun for 10pts, Flamer for 5pts
If the squad numbers 10 or more models, a second Iron Warriors may replace his Bolter with one of the following:
Autocannon for 10pts, Heavy Bolter for 10pts, Lascannon for 20pts, Plasma gun for 15pts, Meltagun for 10pts,
Flamer 5pts
One model may be given the Icon of the Dark Mechanicus
The squad may take a Chaos Rhino dedicated transport.
Fast Attack
Android 40pts each (1-3 per squad, must be split in to the minimum amount of squads possible)
3 0 5 5 3 3 D6 9 –
Special Rules: Fearless, Slow and Purposeful, Mindless
Iron Eagles 20pts each (5-20 per squad)
4 4 4 4 1 4 1 8 3+
Champion +15pts
4 4 4 4 1 4 1 9 3+
Wargear:
Bolter
Power Armour
Jump Pack
Options:
The champ may replace his bolter with one of the following:
Bolt Pistol + Chainsword for free (May replace his bolt pistol for plasma pistol for 15pts extra)
Bolt Pistol + Power Sword for 15pts (May replace his bolt pistol for plasma pistol for 15pts extra)
Bolt Pistol + Power Fist for 25pts (May replace his bolt pistol for plasma pistol for 15pts extra)
One model may take an Icon of the Dark Mechanicus for 15pts
Up to 2 Eagles may replace their Bolter with one of the following:
Plasma Gun for 15pts per model
Meltagun for 10pts
Flamer for 5pts per model
Heavy support
Vindicator 125pts
Wargear:
Hull mounted demolisher cannon
Smoke launchers
Search light
Dozer blade
Options:
Extra armour for 15pts
Dirge caster for 5pts
One of the following pintle-mounted weapons
Twin linked bolter 5pts
Combi weapon for 10pts
Havoc launcher for 15pts
Basilisk (see imperial guard codex)
Chaos Land Raider (see chaos codex)
Defiler (see chaos codex)
Chaos Predator (see chaos codex)
Oblitorators (see chaos codex)
Chaos Havocs (see chaos codex)
Extra Option:
One model may be given a Multi-Melta for 20pts
Orbital bombardment 100pts
S5 AP4
Follows the same rules as orbital bombardment in the warhammer 40,000 codex.
Special rules
Mark of the Dark Mechanicus - The model recieves +1 to their BS
The Dark Mechanicus
Techpriest 60pts
6 0 5 3 2 4 3 10 -
An army may include a single Techpriest. It does not take up any force organisation chart spaces but is otherwise
treated as a HQ unit, however whenever rolling to attack if any of the dice show a 1 the Techpriest goes insane with
the power of Chaos, and inflicts 1 wound upon himself.
Wargear
A single Servo Arm
Special Rules
Fearless
Must be Summond from the Warp using the rules for summoning Greater Daemons in the Chaos Codex
Dark Mechanicus Cultists 13pts per model (5-20 per squad)
4 0 4 4 1 4 2 10 -
Units of Dark Mechanicus Cultists do not take up any force organisation chart spaces but are otherwise treated as
Troop Choices.
Wargear
A single close combat weapon (Bionic arms etc)
Special Rules
Fearless
Must be Teleported to the battlefield using the rules for summoning Lesser Daemons in the Chaos Codex
The End ;)
PHEW!
Please tell me what you think and whether I should Add/Remove/Edit any thing. :P
https://bolterandchainsword.com/topic/135469-homegrown-codex-iron-warriors/
Wow, way to overdone for Iron Warriors players.... it needs to be KISS(keep it simple stupid).
Just give the Iron Warrior players what they want and they will be happy.
4 hvy support choices and the return of the basilisk(with indirect fire)
- No other icons except the Icon of Chaos glory.
-0-1 khorne berserkers( this will make me happy, since I like the IA rules better than the 4th edition rules for them)
- may take obilterators as elite choice 0-1, as well as the normal unrestricted hvy support choice.
Nothing new special gear or weapons...
I no longer care about the Iron Warriors, I've moved on to the Word Bearers and understanding how to properly use lesser daemons and possessed. cannon fodder like them should be. :D ;)
Ahoj!
IA Iron Warriors ... good times, that.
It was that which got me playing CSM, as I never cared for the god-specific legions. After the Haines Codex came out the IW became the ultimate boring SAHF army there was ...
I almost agree with Maladon. So, what he said, but no 4 HS.
The 0-1 Elite Obliterators are exactly that already.
As to the original post - the Arch Obliterator should IMO cost some 100 points. +1BS and +1 inv. for 10 points is too cheap.
Borys
I think the cyber prince is undercosted by a little, a BS5 Kai Gun is nothing to be sneezed at, 25 points was the original codex price, i assume your using the DP as a price base, but this is a thing with a WS 7 S 10 power fist, and a Kai gun, is undercosted at 130 points, i would say 140, perhaps more for it, as he is going to wipe the floor quite badly with most things that come up against him.
Also i dont think that Leman Russes are particularly Fluffy for Iron warriors, they never really used them, only really basilisks, so i would remove them from the list of options.
I think not giving them an extra HS slot but give them a 0-1 slot for obliterators in elite is far better in terms of game balance for the iron warriors, even if it is not so fluffy as giving them more HS slots.
Also, WS6 on a tech marine? Thats more than a loyalist commander, he isnt a combat specialist, make him 4 or 5, hes a technical genius not a duellist and reduce his points accordingly.
Remember you dont want to bring back what everyone hated about facing iron warriors, otherwise you wont get anyone to play against, (I.E the 4 HS slots), your doing a decent job of it however.
Otherwise, not looking bad.
Being an Iron Warriors player for about 5 years now honestly there are just a few things I would like out of the legion
-Allow any mix of Chaos Undivided (or "Glory" or whatever the hell) and Khorne, but no other cults of any kind, not even banners
-No summoned demons
-"Cybernetic Possessed" that have mechanic augmentations so you can pay points for a certain type of implant that guarantees a certain effect (basically the old possessed rules with an excuse to use mechanical parts in conversions)
-0-1 Basilisk and make the Vindicator 0-1 as well, they are kept by the 1st company for chirssake and only loaned out on a case by case basis, 3 vindicators in a 1500 point "small sortie"force makes no sense
-Allow havocs to take tank tank hunters at +3 point/model
-An option for defilers to take indirect fire (honestly all Chaos should get this back)
-No more bloody obliterator slots, "special association" or not, obliterators are supposed to be rare and mysterious, refer to my vindicator comment.
-I suppose servo arms should come back, but maybe at a price at which I wouldn't have to claim that my modeled servo arms actually represent a "close combat weapon" because 30 points for a single attack is horridly inefficient.
-Preferred Enemy:Imperial Fists would be a really fun addition as well, even though I have never actually faced the Fists =/
All in all I think the IA:Iron Warriors rules were the best, but failing that, the Petedex was still better than the homogeneous tripe we have now.
