smelly_squig Posted May 5, 2008 Share Posted May 5, 2008 today is my birthday ;) (19) and my mum gave me a camera so i thought i would write a tutorial to test how my camera works if you want any more pictures just ask and i will try to get them these are designed to be used in my dark mechanicus army which i am planning to start with you will need 1. a necron head 2. a paper clip 3. a small drill 4. a scalpel(or similar cutting tool) 5. a base to put it on http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0020.jpg grab the necron head and cut the chin off http://i166.photobucket.com/albums/u99/smelly_squig/untitled.jpg you may notice the bits where it was attached to the sprue after this picture was taken i removed them http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0028.jpg http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0027.jpg then drill a hole on the bottom behind the top lip(the picture should explain a bit better) http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0029.jpg then get the paper clip and bend it strait now glue the head onto it http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0031.jpg and cut the paper clip so it is a little bit bigger than what you want then bend the end to a right angle http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0032.jpg then drill a hole in the base then push the paper clip in the hole and glue it http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0033.jpg http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0034.jpg now you just need to paint it http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0019.jpg http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0016.jpg (i still need to paint the paper clips black in these pictures but you get the idea) to paint them: black undercoat codex grey higlighted with fortress grey for the front metal bit then bleached bone with a little highlight of white for the back of the skull then the eyes are ultramarines blue highlighted with ice blue the necron destroyer heads work too http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0022.jpg i am using them to represent the more techy servo skulls and a scale picture http://i166.photobucket.com/albums/u99/smelly_squig/DSCN0025.jpg Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/ Share on other sites More sharing options...
wiplash Posted May 5, 2008 Share Posted May 5, 2008 look pretty good is the head with the extra eyes in the warrior box? Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/#findComment-1562721 Share on other sites More sharing options...
smelly_squig Posted May 5, 2008 Author Share Posted May 5, 2008 i dont play necrons so i dont know if it is(i bought them from bitzbox) http://www.bitzbox.co.uk/index.php?cPath=21_28_168 i know its from the destroyer box but i dont know if its in the warrior box as bitzbox doesnt show them on the warrior page i would guess no but i dont know as i have never bought the box Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/#findComment-1562727 Share on other sites More sharing options...
Divergent Reality Posted May 5, 2008 Share Posted May 5, 2008 its a destroyer / heavy destroyer head. its only in the destroyer boxes. Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/#findComment-1562816 Share on other sites More sharing options...
Amon-Chakay Posted May 5, 2008 Share Posted May 5, 2008 At my local store there are two necron players, i'll ask them for some heads, and if you don't mind i'll use your tutorial. i love it! ^^ Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/#findComment-1562819 Share on other sites More sharing options...
smelly_squig Posted May 5, 2008 Author Share Posted May 5, 2008 the first head i did it on came from a guy at my local club who was giving away some spare bits he didnt want(mainly orks and necrons) i have about 17 heads which i got from bitzbox which if they had any left in stock(i bought them :nuke: ) i would advise people to use that as they where really good the reason i wanted them to be so simple was because i think my troops will be complicated and when i get the bits i have ordered from forgeworld and gamesworkshop(which i ordered long before i did the bitzbox order) i may do a tutorial on them too if anyone wants to steal my ideas then please steal away Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/#findComment-1562867 Share on other sites More sharing options...
Divergent Reality Posted May 5, 2008 Share Posted May 5, 2008 At my local store there are two necron players, i'll ask them for some heads, and if you don't mind i'll use your tutorial. i love it! ^^ generally necron players have no spare bits unless they convert a bit. unless you consider spare green rods bits. good luck. Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/#findComment-1562952 Share on other sites More sharing options...
The Emperor's Chosen Posted May 10, 2008 Share Posted May 10, 2008 Yes, all the necron kits come with exactly the number of parts you'll need (heads, arms, etc) for the models. Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/#findComment-1567025 Share on other sites More sharing options...
smelly_squig Posted May 11, 2008 Author Share Posted May 11, 2008 if you dont have access to necron heads you can do it with normal skulls the very first ones i did was made from normal skulls i cut the chins off them just like in these then i started adding little techy bits to them but i found it really hard to add the detail i put wire into the eyes to look like cameras i cut the back half off the skulls and added auspex scanner screen to it i also tried some with chaos warrior helmets but i couldnt find any way to make them look like chaos servo skulls and less like floating helmets i gave up that idea because i wanted to use the helmets for my mechanicus troops and i thought it would look silly but i since then have changed the heads on my mechanicus which i will post pictures of when forgeworld hurry up and send my order and when i have finished all my assignments edit:sorry it posted before i was finished typing Link to comment https://bolterandchainsword.com/topic/135627-modelling-simple-servo-skulls/#findComment-1567676 Share on other sites More sharing options...
