Bolter/Bolt Pistol and CCs
Euraldius
This has probably been mentioned before:
In the new Chaos codex, Chaos marines have a bolt pistol and close combat weapon, and a bolter. Does this mean that they can fire with a bolter one turn, and then whip out a bolt pistol and close combat weapon and charge? Or does the Chaos player have to choose to equip his Marines with either a bolter or the CC combo?
I've had friends argue both ways. So far, I've chosen either bolters or CCs.
https://bolterandchainsword.com/topic/136129-bolterbolt-pistol-and-ccs/
They have all of them. No eithers. ALL. And yes, this means they can use the bolters while they advance, and then clip up their bolt pistols and fire a salvo before charging and fighting with +1 attack in CC because of 2 close combat weapons.
Remember that you can't charge after fireing a rapid-fire weapon though so remember to specify useing the bolt pistols when you shoot before charging :D
TDA
