  • 2 weeks later...
The Nurgle Daemon Prince comes with a 60mm base, so the size for the DP base can be debated. In 5th edition you may not base you model on anything larger then the base it comes with unless you have your opponents consent (GW clearly have no idea how many people there are out there with converted DP with wings (and other large models) that need larger bases so that they don't fall over when they stand on anything but flat ground). This is according to people who have read the finished book.
https://bolterandchainsword.com/topic/136607-dp-gd-base/#findComment-1583665
