Space Shark Whirlwind + Drop Pod, Tact squad & ...
Cpt Stahl
Space Shark Whirlwind, nick-named "Angaur". The rocket launcher is scratch-built, and for those who remember it is similar to the Whirlwind of the early 90's (Epic version).
It also features the alternate Space Shark chapter badge.
Enjoy :D
http://www.pix8.net/pro/pic/10647YL11A/1105782.jpg
http://www.pix8.net/pro/pic/10647YL11A/1105783.jpg
http://www.pix8.net/pro/pic/10647YL11A/1105784.jpg
http://www.pix8.net/pro/pic/10647YL11A/1105785.jpg
Rhino mode :
http://www.pix8.net/pro/pic/10647YL11A/1105786.jpg
http://www.pix8.net/pro/pic/10647YL11A/1105787.jpg
Comments and critics are welcome :)
Cpt Stahl.
@ the Jinster & MarineWithAMullet: plasticard + bits (Example 1 & 2). I took 1mm plasticard. The sides are 2.5 cm high, and 4.5 cm length. The top is 3.7 cm wide and 4.5 cm length. For the square base I cut the borders, and only took 3/4 parts of it. I put it 0.5 cm back in the launcher. Fot he exaust, I was to lazy to build one out of plasticard, so I took an old bit fromm a WW2 tank kit. The other bits can be found on any Marine tank kit.
@ Doghouse and Brother Ziggy : I took a Razorback kit, and this is the twin las-cannon turret. My first idea was to build only the launcher in order to put in on a twin bolter razorback turret (Example 3, Ex 4 ,Ex 5 and 6); For the final result, I choose to fully incorprate the laser turret to the launcher; for this I had to cut the guns, and the result looks like this : under 1 , 2 and 3.
I hope that the pics explain well how I did the launcher :teehee:
@ KYR GKIKAS and OwenCrute : thanks :teehee: (KYR GKIKAS : what about your BT ?)
Cpt Stahl.
I totally want to do that for my Ultramarines.
I have an alternative for my Lamenters though. Playing on the joke that they had most of their stuff taken after the Badab war, I was gonna make a very obviously fake Rhino (i.e. only the front, top and sides, letting the back be open and being pushed along by one marine) and then having a number of scouts on top with missile launchers :woot:
  • 5 months later...
Just finished a Shark drop pod and a tactical squad :
http://www.pix8.net/pro/pic/10647YL11A/1120885.jpg
and a Rhino :
http://www.pix8.net/pro/pic/10647YL11A/1120888.jpg
Comments and critics are welcome ;)
Cpt Stahl.
quick question though whats your painting technique that you used painting the holo display in the pod ?
For the Holo display, first layer in white, then an "Ice blue" layer and finally I put some blue ink (which is no more sold by GW :) ). Maybe try with the new blue wash and a coat of gloss warnish.
Cpt Stahl.
Hahahaha! I love it!
Awesome work as always. I love the shark faces on the drop pod, very intimidating. :)
I really dig how "worn-in" the greys on the drop pod look, makes it feel like something that has sen some action.
Always a pleasure to see more Sharks from you. :tu:
-T.
  • 1 month later...
A couple of month ago, a Terminator/ork sprue was offered with a WD issue. I liked the Termi a lot, so I decided to get a AoBR box (btw the other marines will be the core of a Salamander patrol).
There are the Terminators :
http://www.pix8.net/pro/pic/10647YL11A/1124932.jpg
The assault cannon is from the DA sprue.
Enjoy :cry:
Cpt Stahl.
