Painting: Painting Yellow Quickly
This is the 'new' first stage to my yellow painting proccess (I go a bit further, but this is a good basic/quick way for general troopers etc.).
http://photos-g.ak.facebook.com/photos-ak-sf2p/v309/128/96/633810322/n633810322_3435582_2346.jpg
Stage 1: watered down application of Iyanden Dark Sun
http://photos-h.ak.facebook.com/photos-ak-sf2p/v309/128/96/633810322/n633810322_3435583_2691.jpg
Stage 2: second application of Iyanden Dark Sun
http://photos-a.ak.facebook.com/photos-ak-sf2p/v309/128/96/633810322/n633810322_3435584_3011.jpg
Stage 3: (Blurry sorry) dry brush with 1:1:1 mix of Sunburst Yellow, Iyandn Dark Sun & White
http://photos-b.ak.facebook.com/photos-ak-sf2p/v309/128/96/633810322/n633810322_3435585_3333.jpg
Stage 4: Wash with undiluted Gryphonne Sepia Wash
Once dry (mines not yet <_< ) you can dry brush with sunburst yellow, then yellow/white mix, then watered down Gryphonne Sepia wash, followed by highlights of white/sunburst mix.
Hope that helps someone!! :>
https://bolterandchainsword.com/topic/141255-painting-painting-yellow-quickly/
This is great, and very similar to my method.
Steps 1-2 pretty much the same.
For step 3 I use Golden Yellow and I paint on a few coats instead of drybrushing. - Main difference.
Step 4 is the same, except I only apply the was to the recesses.
Step 5 is highlighting edges with Sunburst Yellow.
It's probably not as quick, but
the result is a more vibrant yellow:
http://i2.photobucket.com/albums/y49/maxh/IMG_0472.jpg
Very nicely done.
Im still trying to figure out how to paint my IF i tried golden yellow with a ogryn flesh wash and then golden yellow highlights which gives them a rather dirty look.
Im still not sure weather to stick to ogryn flesh or to switch to gryphone sepia.
Also I havnt figured out yet how to just apply the wash to the recesses without getting ugly rims on the surrounding flat areas could anyone advice me on that?
  • 2 weeks later...
I haven't painted a lot of yellow, just fooling around with extra models, but I've found if you basecoat white, then take a watered down yellow ink (I used 2:1 or 3:1 h2o:ink) and hit all the areas that will be yellow, that it took less layers to cover and I got a much nicer tone when finished. I'm by no means an expert, but it worked well for me.
  • 4 weeks later...
Wow, I've been totally schooled.
Could you post a full tutorial if you have time? I'd love to see it.
Once dry (mines not yet :wacko: ) you can dry brush with sunburst yellow, then yellow/white mix, then watered down Gryphonne Sepia wash, followed by highlights of white/sunburst mix.
I'm going to have a go at this, but afterwards, glaze it a couple of times with yellow ink.
