2000+ Points of Marines Malevolent Army shot
tagsta
hey guys
I just found time to take a pic of my 2000+ pointish Marines Malevolent Force
also wrote a little fluff. Please don't be too harsh with my untalented writing skills haha :huh:
what I changed for the 5th edition:
- changed squad sizes to either 5 or 10 man
- changed my command squad to Sternguard Vets (close up pics as soon as more squad members are finished)
what I planned for the future:
- all squads will be extended to 10 man
- Masters of the Chapter, Chapter Master with Honor Guard and Command Land Raider (50% done yet)
- a Terminator Squad
- another Tactical Squad
- 3 more Rhinos
Picture shows Marines Malevolent Strikeforce operating on Artesia Prime
Commanded by 5th Company Captain Tauran Demos
http://i3.photobucket.com/albums/y68/Tagsta/Warhammer40k/Marines%20Malevolent/0army.jpg
5th Company Elements
5th Company Commander Demos
Apothecary
2 Librarians
1x Tactical Squad
2x Tactical Demi Squad
1x Assault Squad (4Squad Members seconded to operate Land Speeders)
1x Devastator Squad
1x MKIV Siege Dreadnought
1x MkIIc Rhino APC with improved Communications
2x MkIV Razorback APC
1st Company Support
1x Sternguard Demi Squad
10th Company Support
1x Scout Recon Squad (setting beacons for Whirlwind Platforms)
1x Scout Sniper Squad
Armoury
2x Land Speeder Tornado (operated by 5th Company Assault Squad Members)
2x Lucius Pattern Vindicator Siege Tank
2x Helios Pattern Whirlwind Platform (remote controlled)
My Dear Inquisitor Lord,
here is the report about the incident in the Adeptus Mechanicus Research Station located on Sector 52 on Artesia Prime you requested.
My intelligence agent uncovered the role of the Marines Malevolent Adeptus Astartes Chapter and Ordos Xenos Inquisitor Rouven Malay during the Liberation of Artesia.
The Liberation Forces under Imperial Guard High Command were promised support by the Marines Malevolent Astartes Chapter during the Rebellion on Artesia Prime.
The Marines Malevolent were supposed to take down the four heavily fortified Arbites Outposts occupied by the rebels before the main Imperial Forces would make planetfall.
The Astartes surgical strike should minimize casualties of the Imperial Forces and enable the Imperial Guard Armoured columns to securely enter the main roads to the Hive and wipe out the enemy resistance.
Phase I
Without communication to the rest of the fleet Strike Cruiser Fist of Golgotha quickly engadges Artesia’s Orbit and launches several small objects later on identified as drop pods.
Phase II
Planetary Defence forces report artillery bombardment in loyalist controlled Sector 52 located in the outer rims of the hive. A small intervention force is send out to investigate the incident. PDF forces report a large number of destroyed civilian buildings. Tremendous civilian casualties are reported.
The intervention force is faced by Heavy Bolter fire from the ruins close to the source of the bombardment
The contact to the PDF forces breaks down shortly afterwards. Wounds inflicted on the corpses of the guardsmen were later identified as characteristical damage caused by the special ammuntion type, commonly used by Astartes Sternguard Veterans.
Phase III
The Astartes Strike Vessel lauches Thunderhawk Transporter dropships. Liberation Forces headquarters still can’t establish communication with the Space Marines.
Phase IV
The Fist of Golgotha enters lower orbit and begins orbital bombardment on the rebel outposts.
Phase V
The Astartes dropships don’t engage the rebel outposts and make planetfall on Sector 52 instead. Heavy fighting in the ruins that were destroyed by the artillery barrage is reported later.
Eye witnesses from the refugees located in Sector 52 report fire and explosions within the Adeptus Mechanicus Research Area. A convoy of Astartes tanks is sighted close to the Research Station.
Figure 1
Space Marine Armoured Convoy
http://i3.photobucket.com/albums/y68/Tagsta/Warhammer40k/Marines%20Malevolent/1convoy.jpg
Figure 2
Space Marine Combat Formation
http://i3.photobucket.com/albums/y68/Tagsta/Warhammer40k/Marines%20Malevolent/2numbers.jpg
I. Vanguard
Vindicator Tanks leading the column
II. Main Troop Convoy
Rhino with modified Communication array (unidentified pattern) Razorback APCs
supported by Dreadnought with Siege Weaponry
III. Demi Squads advancing through buildings
supported by Assault Squad
IV. Rearguard
Tornado Land Speeder ready to intercept/engage
Shortly afterwards the barrage from the Astartes Strike Cruiser ceases and the Astartes dropships return to their main vessel.
The Fist of Golgotha leaves the sub-system immediately afterwards.
Visible damage by Melta bombs and assault drills was reported on the structure.
The Administation of the Adeptus Mechanicus Station still can’t be contacted so there is no official statement at this moment.
All I know is that the casualties that the civilians and the PDF forces took are tremendous.
Figure 3
Pict taken by intelligence officer (killed in action)
http://i3.photobucket.com/albums/y68/Tagsta/Warhammer40k/Marines%20Malevolent/4pic.jpg
A Squad of Marines Malevolent with their APC transport, Inquisitor Rouven Malay, and an Adeptus Mechanicus Member believed to be Magos Biologis Kaleb.
Note the Sergeant’s Shoulderpad with the Inquisitoral Symbol.
I have to oversee the deployment of the Liberation Forces and can’t deal with those matters at the moment but I have serious concerns that the Marines Malevolent and the Ordo Xenos Inquisitor are somehow involved in the incidents. Please forward my report to the agents of the Ordo Hereticus for further investigation.
Your Servant
Thias Aggripan
Artesia Prime Liberation Forces High Command
hope you guys like it ;)
-tagsta
/edit
here is another pic from the convoy taken from my arvus lighter :whistling:
http://i3.photobucket.com/albums/y68/Tagsta/Warhammer40k/Marines%20Malevolent/1aconvoy.jpg
*insert extreme profanity*
Dayum they are good!!!
thanks :D
Great looking force! Not too many Astartes with that scheme running around.
Would like a close up or two on the whirlwind turrets, if you have a minute.
http://i3.photobucket.com/albums/y68/Tagsta/Warhammer40k/Marines%20Malevolent/turret.jpg
there you go
"real" close ups with blue background and stuff as soon as I do my next photosession
long time no read from you Tagsta.great story for a great army
I'm afraid that's right
I wasn't lazy but I just didnt have time to take pictures
you'll see a thread of a Sisters of battle commission army and a few close ups of my projects very soon
What I meant was, did you take the shots with the special effects of the new mac computer? cause the first surveillence pic is really similar to one of the cool effects you could overlay on a picture. Sorry if it wasn't clear.
oh you mean those special modes from the photobooth software.... no I took a pic with my digi cam and did the effect by hand using photoshop
Tagsta you've been busy !! great looking min's mate, and I think all the positive response on this thread just goes to show how much good work is going on here from the build right through to how you've presented them to us ! I'm now slinking off to hang my head in absolute shame. well done sir !
WOW! I'm blown away! That is just amazing, Tagsta!
Your army looks great and the pictures and story are a nice touch.
Awesome!
alright thanks to the MkV god B)
still envy your marine :)
They are freakin AWESOME mate!
You got that yellow spot on for those guys, well done!
All that looks amazing
Really nice.
I like the 'satelitte imagery' and 'real-time imagery' too! Nice touch!
Really well done. Great job on the article photos... very 'Forgeworld-esque'.
thanks for the kind words guys, appreciate it a lot!
will post some more updates as soon as I finished the chapter masters and stuff and get the army apocalypse ready
I just love your Helios AA platforms. I'm looking into those for an Apoc game and I wasn't really sure what to do for the base. I really like the simple lines of your bases.
Thank you for that inspiration.
BTW, love your army. I know you've been told this a million times before, and it is true for "yellow" armies, but you have really pulled off something special. It is an army to be very proud of.
Cheers,
  • 2 weeks later...
So.. I'm a little sketchy on this.. They are good guys right? Might just be how I'm reading it, but it came off with them sounding like bad guys.
Another small critique is that loyalist messages tend to be very prim and proper, without opinions, except with a note or two at the very end. But that's just what I've seen in official fluff.
I like your army very much though.
Marines Malevolent had some rather shady fluff in the Armageddon codex as I recall. They seem like the sort that "The Ends Justify the Means" but I could be wrong about that! Otherwise....GORGEOUS army! And such a distinct yellow from Imperial Fists...its a joy to see...
Always impressive when you see a picture of a big army, especially impressive when it's well painted - and yellow. ;)
Great job so far, makes me want to bring out my own MM again (if only yellow wasn't such a pain to paint, oh well).
  • 5 weeks later...
