Seeking an alternative Daemon Prince and/or Greater Daemon
I've just started work on a Fallen Angels army. I'm using DA vets, all with Cypher's backpack, and the CSM book.
I'm struggling with what to use as a Greater Daemon or Daemon Prince.
My requirements are
Floor length robes
Sword
Much taller than a terminator
Big enough to warrant using a base larger than 40mm
The only model I found in the GW range was Sauron the Necromancer. Head and arm swaps, job done. But I'd rather have something that looks more power armoured.
Any ideas?
Here's Widowmaker's Fallen Angel Daemon Prince for inspiration:
http://i150.photobucket.com/albums/s106/widowmakerphotos/Games%20Workshop/Warhammer%2040K/Chaos/Marines/Fallen/In%20Progress/P1000840.jpg
iirc it was built on the existing DP with Inquisitor Range bits.
Thanks for the shout out Nihm... Yeah, it was built from the standard DP with Green Stuff and an Inquisitor scale Space Marine Helmet.
@Hammerofulric - you can go the Inquisitor scale route too. The robes are a littl harder to put together, but worth it I think.
This is my other DP from Artemis...
http://i150.photobucket.com/albums/s106/widowmakerphotos/Games%20Workshop/Warhammer%2040K/Chaos/Marines/Fallen/In%20Progress/P1010123.jpg
And a side view...
Hope it helps. Look forward to seeing what you come up with.
Cheers
Widowmaker
Alternatively, if you want to avoid the 'giant space marine' look you could try using the Nightbringer C'Tan.
He's been used as the basis for a Mortarion/Nurgle DP many times thanks to his 'angel of death' style. Could look really nice in a mostly robed Fallen army.
