Started Painting Terminator, opinions? [completed]
nurglespuss
Hi all
http://photos-c.ak.facebook.com/photos-ak-sf2p/v338/128/96/633810322/n633810322_3946802_9827.jpg
http://photos-a.ak.facebook.com/photos-ak-sf2p/v338/128/96/633810322/n633810322_3945112_1144.jpg
http://photos-322.ll.facebook.com/photos-ll-sf2p/v338/128/96/633810322/n633810322_3934189_1448.jpg
Just started to 'slap some paint on' the squad is going to consist of 3 Children of Icarus (with lihtning claws) and 3 Aurora chapter with thunder hammers.
Please let me know what you think so far of green stuff/pain/idea for scheme :> cheers! also not 100% sure on colour for robes....
update: No I'm not liking the robes, but for a first attempt (using B&C tutorial) I'll let it slide. I do quite like the chain though, any thoughts? Cheers (p.s. Plus I wanted them to look dirty/worn, but not decrepid).
Hi there :> I found an awesome tutorial on you tube which showed me how, essentially though, its a 'line' of greenstuff, gently indented into square secitons, gentlyround of the corners of each section, and then (I used the blunt tip of a thin sculpting tool) press into each section to create a 'ring'. You should now have a line of rings. Now the trickier bit, roll out a thin sausage/line of green stuff (thiner than original) and lay along the top of your 'rings' so you can see a bit of ring either side. Now, using a thin slightly pointed sculpting tool, indent this line into each 'ring' so that by the end you are left with a flat, heavy looking chain.
This is the link, it took me one attempt to get right, I was well pleased!
