Second Attempt at Terminator Robes
nurglespuss
http://photos-g.ak.facebook.com/photos-ak-sf2p/v338/128/96/633810322/n633810322_3949174_7367.jpg
Right, attempt no.2.
This time I sculpted on the robes with the head and torso as a seperate piece, and sculpted the groin cloth on a bit of acetate/cellophane before lifting it, and fitting it.
Its not perfect, but I think it looks more like cloth than the last one?
Cheers all, your comments really help!!
Cheers :D LB, I've been making 'cloaks' for various models for a long long time, and simple icons, bionics etc. but have found robes a bit of a no go, until I decided to bite the bullet and try following a tutorial.
Thanks again :>
Not bad. Your sculpting is too heavy though. Remember that small depressions become much more visible with shading and highlighting (like those mold lines that are almost invisible until you paint the damn thing).
The cloth looks like you lifted it too soon. You should let it dry for about 30-40 minutes before liftinf so you don't deform the sculpting but the green is still pliable enough to be pushed into place.
Cheers :> I will keep practicing! and try for lighter sculpting :>
Indeed. My early attempts to sculpt weren't nearly as good as this. If you want to improve make sure you have a good range of tools. At the moment I'm using small clay shapers- they're pliable so seem easier to control than metal ones and they're great for smoothing greenstuff. If you haven't got some already you may find them a worthwhile investment.
