Sigismund Himself Posted September 6, 2008 Share Posted September 6, 2008 The Liber has a brand new sticky! Linky. It is a catalogue of all those Index Astartes that have been placed into the Librarium. All the images, barring one or two, were done by our resident Colour Scheme Wizard, Dazzo. If you're unhappy with how your scheme has been represented on it, you may replace it. Some limitations apply. It must be roughly the same size, have a white background and size 11 Times New Roman font, all capitols. That way they all look equal as well as nice and neat. Enjoy! Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/ Share on other sites More sharing options...
Wolph Posted September 6, 2008 Share Posted September 6, 2008 Wow that looks great Sigismund ;). What must I do to join such honored ranks? Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1684003 Share on other sites More sharing options...
Ferrata Posted September 6, 2008 Share Posted September 6, 2008 Quick point, can you remove all the symbols from the Black Guard shoulder pads, the only exterior symbol shown by the chapter is that on the right knee. Cheers, great work. Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1684006 Share on other sites More sharing options...
Sigismund Himself Posted September 6, 2008 Author Share Posted September 6, 2008 Wolph: Once you've written your IA, post it up here in the Liber. Refine it and keep polishing it. Get it looked over by the Liberites. Then go into the Librarium, click on the New Article button, paste your IA in and click submit. A member of the Librarium Staff will contact you back regarding if it has been published and/or giving you some advice on how to improve it to Librarium standard. Don't be worried if you get knocked back on the first attempt, some of the chapters in there have gone through at least 3 rejections before being accepted. And they're the better for it ;) Ferrata: I'll try and edit that image sometime tonight. Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1684012 Share on other sites More sharing options...
Dazzo Posted September 6, 2008 Share Posted September 6, 2008 Ferrata: I'll try and edit that image sometime tonight. No need, its already been done ;) Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1684018 Share on other sites More sharing options...
Commissar Molotov Posted September 6, 2008 Share Posted September 6, 2008 Would it not make sense for the Chapters to be displayed alphabetically? Also, that Castigator's a little light - plus, the Castigators don't have white shoulder pads or a white stripe down their helmets. And they display a Company badge on their knee, but I can let that go. :( Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1684274 Share on other sites More sharing options...
Dazzo Posted September 6, 2008 Share Posted September 6, 2008 :( whoops not sure what pic I was looking at then. I shall correct the oversight forthwith ;) Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1684307 Share on other sites More sharing options...
Ferrus Manus Posted September 6, 2008 Share Posted September 6, 2008 Looks good Dazzo! My only problem is that the Arctic Lion's gauntlets arn't the pale blue-grey that they should be. But nice work once again. Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1684321 Share on other sites More sharing options...
Sigismund Himself Posted September 6, 2008 Author Share Posted September 6, 2008 Would it not make sense for the Chapters to be displayed alphabetically? It is easier to make it in order of publication. That way, every time you get a new chapter, adding it doesn't require having to move everything down the table. The table coding is fairly complex and easy to screw up so it's a lot easier this way. Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1684555 Share on other sites More sharing options...
Dazzo Posted September 8, 2008 Share Posted September 8, 2008 My only problem is that the Arctic Lion's gauntlets arn't the pale blue-grey that they should be. But nice work once again. How pale are they because pale blue and pale blue grey can be very similar colours on the painter. If you want it changed its not a problem but if you can live with it... ;) Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1686231 Share on other sites More sharing options...
Ferrus Manus Posted September 8, 2008 Share Posted September 8, 2008 How pale are they because pale blue and pale blue grey can be very similar colours on the painter. If you want it changed its not a problem but if you can live with it... Its the same blue-grey as the helmet, but its ok I'll live with it. Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1686244 Share on other sites More sharing options...
Brother Barkus Posted September 9, 2008 Share Posted September 9, 2008 Curses I've been taking time to play the actual game these last two months and have now been inspired once again to attempt a succesful DIY. Curse you for your excellent work fellas. Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1686954 Share on other sites More sharing options...
Wolph Posted September 9, 2008 Share Posted September 9, 2008 Curses I've been taking time to play the actual game these last two months and have now been inspired once again to attempt a succesful DIY. Curse you for your excellent work fellas. Double curses for the great work as I myself am inspired to do the same. DIY under construction Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1686990 Share on other sites More sharing options...
Barret Posted September 10, 2008 Share Posted September 10, 2008 Castigators and Black Guard images have been updated. Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1689119 Share on other sites More sharing options...
Dazzo Posted September 11, 2008 Share Posted September 11, 2008 Is the one thats missing the Eagle claws? Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1689554 Share on other sites More sharing options...
Barret Posted September 11, 2008 Share Posted September 11, 2008 Yes. Link to comment https://bolterandchainsword.com/topic/145268-liber-honouros-index/#findComment-1689988 Share on other sites More sharing options...
