Wolf89 Posted September 10, 2008 Share Posted September 10, 2008 For the last 2 missions there is a note at the bottom both both pages. "Note: If your opponent does not have any units of a particular type (i.e. they have no Fast Attack choices) then you automatically receive the battle point modifier for destroying them." Now this is for the 2 missions where you use annihilation, and for troops it's 1 point, for elites and everything else but HQ it's 2 points, and for HQ's it's 3. So is this note saying if my opponent doesn't have an elite choice then I get 2 points automatically or 6 points (for the 3 slots not taken). I believe it's the first one, but not sure. Also, when you kill a troop, or HQ or something, it's however many points each time correct? so if I face oh, a SW player who has a mandatory of 4 HQ's there's a potential of 12 points right there?! seems a bit off but whatever I'm also not pleased with the first mission... 5 objectives, with my only 3 troops... -_- I may have to take out those storm claws, and try to at least get another squad of grey slayers... ugh... Link to comment https://bolterandchainsword.com/topic/145693-ard-boys-mission-questions/ Share on other sites More sharing options...
Brother dean Posted September 10, 2008 Share Posted September 10, 2008 No you only get the +1 battle point modifier for destroying all HQ/FA/Troops/HS Battle Point Modifiers+1 if you destroyed all of your opponen’ts Heavy Support choices. +1 if you have destroyed all of your opponent’s Fast Attack Choices. +1 if you destroyed all of your opponent’s HQ choices. +1 if you destroyed all of your opponent’s Troop choices. Link to comment https://bolterandchainsword.com/topic/145693-ard-boys-mission-questions/#findComment-1688978 Share on other sites More sharing options...
Wolf89 Posted September 10, 2008 Author Share Posted September 10, 2008 Ard boyz uses different rules as follows; "Kill Points in Ard Boyz are figured out on the following way: Troop Choices - 1 Kill Point Fast Attack/Elites/Heavy Support - 2 Kill Points HQ - 3 Kill Points Dedicated Transports do not provide Kill Points" -I see I used the wrong table, so It would just be 1 point I see. - *edited for clarification* Still, if you kill the SW players 4 HQ's that's 3 points each for a total of 12 points, then an additional 1 point from battle modifiers! Link to comment https://bolterandchainsword.com/topic/145693-ard-boys-mission-questions/#findComment-1688996 Share on other sites More sharing options...
