Agrab Posted September 11, 2008 Share Posted September 11, 2008 Okay, so i was playing a game with Adoneus the other day and ran into this issue. The BRB says that even if several separate units occupy one force org they roll to come in separately. However, Demonhosts say that they ARE one unit and just deploy separately. So, do I need to make one roll for each or one roll for the squad? Link to comment https://bolterandchainsword.com/topic/145714-demonhosts-deepstricking/ Share on other sites More sharing options...
nighthawks Posted September 11, 2008 Share Posted September 11, 2008 I believe that you roll per component of the slot if they act independently. this is definitely the case for things such as an IG platoon... Link to comment https://bolterandchainsword.com/topic/145714-demonhosts-deepstricking/#findComment-1689591 Share on other sites More sharing options...
Agrab Posted September 11, 2008 Author Share Posted September 11, 2008 I believe that you roll per component of the slot if they act independently. this is definitely the case for things such as an IG platoon... The issue is that the book says they are separate units but take ones slot (which means you roll for all kill points separately, interestingly). The codex I would say over rides this by saying they ARE ONE UNIT Link to comment https://bolterandchainsword.com/topic/145714-demonhosts-deepstricking/#findComment-1689690 Share on other sites More sharing options...
