First painted minis.
Askren
So I finally got ahold of a camera and took some crappy pictures of my first few painted minis. Now, bear in mind, I've been away from this whole thing for about 8 years, and I've developed quite a shaky hand since I last held a detail brush, but all in all, I think I'm not terribly bad. My solid color painting skills are decent, as far as I can tell, but highlights and shadows are giving me some trouble.
First mini- utter failure
http://img.photobucket.com/albums/v713/HunterMage/CIMG0708.jpg
Second...slightly less so, but still a failure.
http://img.photobucket.com/albums/v713/HunterMage/CIMG0709.jpg
Third, and, hey! We're making some progress! Attempt at at putting some purple on the black edges to bring out the pink messed up most of the model, though.
http://img.photobucket.com/albums/v713/HunterMage/CIMG0720.jpg
Fourth, and not bad if I do say so myself. Still needs an ink wash and shadows/highlights. Lots of gold on this guy.
http://img.photobucket.com/albums/v713/HunterMage/CIMG0699.jpg
http://img.photobucket.com/albums/v713/HunterMage/CIMG0701.jpg
Fifth, and I'm determined to make this guy great! Wish me luck!
http://img.photobucket.com/albums/v713/HunterMage/CIMG0707.jpg
https://bolterandchainsword.com/topic/145988-first-painted-minis/
Hi askren, not bad so far and it's always hard to get back up to speed. As mentioned it would help if you thinned your paint and your base colours are to bright to start with and this will tend to make high lighting more difficult as the contrast is much harder to achieve. So I'd start with a darkeer base colour wash that with a thinned darker shade and then gradually start highlighting from there. The thinned paint will also help to show up natural highlights that are much easier to follow.
Hey there :> as others have said, have faith!
I can see the improvement from figure to figure. Indeed thinning your paints a little is in order, but also use the new washes, and keep practicing.
Pink is one of the harder colours to get right, and pink over black even more so, so you've picked a challenge there! As we can see from your ultramarine, you can paint fine, just need to pick your colours.
Anyway good luck! take your time, and write things down, it helps to remember trial and error techniques :>
One thing that I would say is that all your figures so far shouldn't be considered 'failures'. Each figure is a part of a learning curve and things will come together. As someone has already said; pink is a tricky colour to highlight so it shows that you've got courage with your colours. One thing that I've found which are very useful are the new GW washes - they are far more user friendly than the previous inks and would help give depth and definition to your figures. Hope that helps.
Thanks for the tips! I've been meaning to put together a wet palette for a while now, just haven't gotten around to it. I assume it will help my pinks a lot once i get the coat thickness right.
That said, I've started an Ultramarines squad which will get picture-ified soon. I basecoated them black and dry-brushed thee blue up from there, as I rather like the darker look. They're trimmed in gold, and I'm taking extra care with details.
As for the Chaos and their odd positioning: I had some random, stupid notions of 'converting' them using only the bits that came on the sprues, which basically led to me hacking apart almost all of the arms I had for various random 1-handed bolter & chainsword combos. For that particular guy, I basically took a chainsword from the left hand, and put it in the right hand, slightly cocked to the side so he can hold it over his head and look like he's yelling.
