Vanguard heroic assault
northoceanbeach
A very important difference is the terminology difference in 4th and 5th.
A unit can no longer "fleet". Fleet is now an ability not a verb. The unit can "run" and if it has fleet then it can assault after the run.
Its a tiny anally-retentive thing, but it will help clear up confusion for people not 100% with the rules yet.
Also, as far as im aware you can run instead of shooting. If you're not allowed to shoot, then it follows you are not allowed to run.
However if im mistaken about the run being instead of shooting then there is precedence for you running (and then charging) as regular deepstriking units can still run after the strike.
It very specifically states that Divine Intervention can't be used if a character is part of the squad.
Divine Intervention works as such:
You declare you are going to use divine intervention.
You deepstrike.
Regardless of how bad you scatter, you cannot run nor can you shoot.
If you are within assault range, you may assault.
You deepstrike.
Haha, been playing to many Sisters of Battle? ;) You mean Heroic Intervention. ^_^
Phil
