The Ordo Malleus sent some reinforcements!
Hicks
I finally received the stuff I ordered from FW, so I didn't waste any time and went off to finish my Grey Knightdreadnoughts. A few magnets and some glue and they'll be ready to prime:
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/002-2.jpg
Sure:
The first one in detail:
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/003-3.jpg
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/009.jpg
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/010.jpg
The second:
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/006-1.jpg
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/008.jpg
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/007-1.jpg
The 3rd:
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/005-1.jpg
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/011.jpg
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/012.jpg
Wow those look really good. How did you manage the torsos? They don't look heavily greenstuffed but the result deffinitely looks good.
This is roughly how they're done:
First, you'll need to cut a rectangle in plastic card roughly the size of the hole in the dreadnought front plate like so:
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/001-4.jpg
Then you glue it inside and wait for it to dry. Then apply greenstuff to the contour and pour some water on a flat surface. Lay the dreadnought front plate flat on the water and apply a sanding motion. The GS should smooth out the cracks and the eccess should go away. You should end up with something like this:
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/002-1.jpg (not that I didn't wait long enough for the glue to dry on this pictures so the plastic rectangle got pushed inside, the end result is still a flat surface).
Now it's time to prepare the terminator torso. Take a torso like this one: http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/003-2.jpg
Now cut away the flash and flashlights like so: http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/004.jpg
Now what you want to do is to sand the part indicated by the red line:
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/008-2.jpg
Just lay the torso flat of fine sand paper and sand away. Do it in several shots so you can compensate in case the sanding isn't totally straight.
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/007.jpg
http://i207.photobucket.com/albums/bb196/HugoS_album/Grey%20Knights/006.jpg
Now just take a space marine backpack and cut the bottom so it fits under the terminator torso, you can add GS to fill the gap, but it's invisible unless you pick-up the model to look under it. Glue it on and add the termie torso. Fill the gap in the neck with GS and find a suitable head. Sand the back of the head until it fits in the torso and cut a bit of the neck and voilà, dreadnought ready.
Hope it helps.
