Land Raider Prometheous Sponsons
Vassakov
Right, here's my question - A LR Prometheous has two Sponsons, each with 2 Twin Linked Heavy Bolters. The question is the two heavy bolters seperate weapons for the purposes of firing and Weapon Destroyed results? I know of no other vehicle with this set up (eg two guns on one fire point) - the Crusaders Hurricane Bolters are defined as one weapon.
Anyone got any ideas?
https://bolterandchainsword.com/topic/147535-land-raider-prometheous-sponsons/
The new Prometheous uses a new flamer type on the sponsons (hence the name.) They're independant weapons.
*sigh* No... that's the Land Raider Redeemer, not the Land Raider Prometheus.
As to the OP, I'm fairly sure that they each count as a separate weapons system (so you have four to destroy in total) as, despite the mounting of the model, the rules say nothing about them being co-axial or any similar wording.
I think the point was that they are two twin-linked weapons.
Clearly, if a normal TL weapon is destroyed, we all know that both 'halves' are destroyed, as it is effectively one weapon with a special rule.
If you have two hull mounted weapons, they don't both get wrecked when one weapon destroyed result is rolled, so I don't see why it should be the case with two sponson mounted weapons. Unless anyone knows of a rule that says so?
the hurricane bolter is a defined weapon, and consists of 6 bolters acting as 3 twin linked weapons. it is one weapon in terms of firing, destroying, etc...
the Prometheus has 4 TLHBs, defined as a single weapon type, as 2 weapons per sponson. they are fired & destroyed piecemeal. see P8 of the 2006 Imperial Armour Update.
The difrence is rather simple.
Ignore where the weapons are loctaed.
Normal Land Raider:
1x twin-linked lascannon
1x twin-linked H-Bolter
Crusader:
1x twin-linked assault cannon
1x twin-linked hurricane bolter
1x meltagun
Prometheus:
and some other weapon that i cant remeber right now ;)
In each cae when it comes to weapon destroyed you simply cross one of these weapons off the list and keep playing with what is left.
Take into consideration the ruling on dreadnought arms. Stormbolter goes with the DCCW if destroyed, so perhaps consider a houserule if RAW is unclear.
Question is; does DREADNOUGHT ARM = TANK SPONSON?
Seems like something you'll always need to clear with your opponent before every game - because it also affects how many weapons can fire after moving, which any opponent will be sure to consider.
I favour the ARM = SPONSON interpretation, as otherwise I think the tank is borderline useless.
Which is a pity, cos its the best-looking landraider around. :)
