juckto Posted October 4, 2008 Share Posted October 4, 2008 Contents Black Flames Bone Metals Browns Reds Part 1 - Converting Hall of Honour thread Black 20-25 min per model The paints:http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/black_0.jpg"Shadow Black" - 3:1 Chaos Black:Codex Grey. "Navy Grey" - 1:1 Chaos Black: Codex Grey. I spraycoated the model with Chaos Black spray then touched up any areas with watered down Chaos Black paint.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/black_1.jpg Then I went over all the armour with Shadow Black.It's so dark you can hardly tell the difference between it and black, hence the name.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/black_2.jpg Then give the highpoints a touch of Navy Grey. http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/black_3b.jpg Final highlights with Codex Grey.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/black_4b.jpg And there you have it, a nice simple, muted black. Flames 15-18min each The paints:http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/flames_0.jpg"Fluro Orange" - (60:30:10 Bad Moon Yellow: Fiery Orange: Skull White) You've got two options. You could carefully draw flames on to the armour, agonising over every stylised curve and get something which looks like it belongs on a Boy Racer's car, or you can be smart and realise that flames are random.Take the Blood red and draw some random curves on the armour. The important thing to remember is that straight flames are boring.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/flames_1.jpg Then start joining them up and filling in the base of the flames.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/flames_2.jpg Go over the centre of the flames with Fiery Orange.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/flames_3.jpg Finally get the Fluro Orange and add tiny little triangles at the base of the larger flames.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/flames_4.jpg The final step is to go back over it with greys, making the tips of the flames a little less blunt if they need it, and/or touching up the armour where you spilt - but that can be left till the end. Bone ~1hr 15min each The paints:http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/bone0.jpg"Caramel" - 1:1 Snakebit leather : Bronzed Flesh, iirc. Basecoat with Bestial Brownhttp://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/bone1.jpg Go over it with Caramel, leaving a bit of the brown in the recesses.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/bone2.jpg I use watered down Bleached Bone. I sort of dab this on where I want the highlights and kinda smear it across the rest of the model giving the whole lot a bone tinge; then add bit more on the highlights so I have a solid coat of bleached bone there.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/bone3.png Final highlights with skull white.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/bone4.jpg Metals 20min each Paint the metals with Boltgun Metalhttp://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/metal1.jpg Give them a wash with watered down Black Inkhttp://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/metal2.jpg Add a couple of highlights with Boltgun Metal and, if that isn't enough, Chainmail.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/metal3.jpg ... Odd. When I did Part 1 I could just make a 2nd post to get around the image limit restriction. Now I can't. Quick! Someone reply so I can get post 3! Link to comment https://bolterandchainsword.com/topic/147870-painting-legion-of-the-damned/ Share on other sites More sharing options...
Cpt Ultio Posted October 4, 2008 Share Posted October 4, 2008 This is looking pretty nice, I might use some pointers here for my own projects. Link to comment https://bolterandchainsword.com/topic/147870-painting-legion-of-the-damned/#findComment-1715594 Share on other sites More sharing options...
juckto Posted October 4, 2008 Author Share Posted October 4, 2008 Browns ~12 min each Basecoat Bestial Brown:http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/brown1.jpg The belt pouches etc where highlighted with Snakebit leather.The parchment was coated in Graveyard Earth.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/brown2.jpg The puches were give a final highlight of "Caramel", and the parchement was highlighted 1:1 Graveyard Earth:Skull White.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/brown3.jpg Final highlight of Skull White.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/brown4.jpg Reds 10min each Gun casing and Eyes were done the same way. Basecoat with Scab Redhttp://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/red1.jpg Highlight with Blood Red.http://i14.photobucket.com/albums/a329/juckto/Wh40k/LotD/red2.jpg Flesh I hummed and hahhed for a while about how to paint the seargents face, then ended up going with SilverTabby's excellent tutorial, with slightly paler tones than normal. You can see pics of the finished squad in Hall of Honour Link to comment https://bolterandchainsword.com/topic/147870-painting-legion-of-the-damned/#findComment-1715596 Share on other sites More sharing options...
Sergeant Centurius Posted October 4, 2008 Share Posted October 4, 2008 You've outdone yourself again. Keep up the good work and the Legion of the damned tutorials. --Sergeant Centurius-- Link to comment https://bolterandchainsword.com/topic/147870-painting-legion-of-the-damned/#findComment-1715634 Share on other sites More sharing options...
BrotherAtrox Posted October 4, 2008 Share Posted October 4, 2008 This is really one of the best tuts around. I might buy Black Reach just to try this myself. Link to comment https://bolterandchainsword.com/topic/147870-painting-legion-of-the-damned/#findComment-1715648 Share on other sites More sharing options...
juckto Posted October 4, 2008 Author Share Posted October 4, 2008 Black Reach? You could just do it on normal marines, you know. Keep up the good work and the Legion of the damned tutorials. Well, these models were kinda done as a "one off" just to create this tutorial. I'll be returning to my Pyre army for the foreseeable future, but once I have that finished maybe I'll come back to LotD. I have a few more ideas for conversions :P. Link to comment https://bolterandchainsword.com/topic/147870-painting-legion-of-the-damned/#findComment-1715665 Share on other sites More sharing options...
