madscuzzy Posted October 6, 2006 Share Posted October 6, 2006 Step 1: Get a ball of GS. Doesnt hurt if it has cured slightly, say for about 10-15 mins. http://www.scuzworks.com/SL40K/tutorials/tabard_1.jpg Step 2: Flatten it into its rough shape on a nice flat surface. I use my plastic box here, as GS doesnt stick too well with that kind of plastic. A bit of talcum powder or oil can help prevent the GS from sticking. The semi cured GS does make it less sticky so that is another plus point for waiting. http://www.scuzworks.com/SL40K/tutorials/tabard_2.jpg Step 3: I start with a V-shaped or triangular fold across the top. The top edges are whats going to be joined to the belt so thats where the stress points are. http://www.scuzworks.com/SL40K/tutorials/tabard_3.jpg Step 4: Next I add another elongated triangle down the centre. I also make the cuts taper towards the top and also across the surface to give it some smooth shape. http://www.scuzworks.com/SL40K/tutorials/tabard_4.jpg Step 5: The other side of the triangle... http://www.scuzworks.com/SL40K/tutorials/tabard_5.jpg Step 6: I define the left side of the tabard, adding the more defined fold, similar to the triangle effect done on the centre. http://www.scuzworks.com/SL40K/tutorials/tabard_6.jpg Step 7: I cut the left triangle in half, adding yet another fold. By now you should be realising it all about triangles. http://www.scuzworks.com/SL40K/tutorials/tabard_7.jpg Step 8: And one more, on the right side. http://www.scuzworks.com/SL40K/tutorials/tabard_8.jpg Step 9: Chop down and neaten as necessary. Note that my folds are softer towards the bottom, as cloth doesnt bunch up as much as it would at the top. Working with this stage at the aroundd 1.5 to 2 hr mark allows you to bend the GS into a more flowy shape helps to make it not look so stiff. http://www.scuzworks.com/SL40K/tutorials/tabard_9.jpg Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/ Share on other sites More sharing options...
Master Chaplain Astador Posted October 6, 2006 Share Posted October 6, 2006 Very nice! I wish I could sculpt like that! lol I might have to try this out tonight! Thanks for sharing Madscuzzy! Cheers, The Master Chaplain. Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1110877 Share on other sites More sharing options...
monstagames Posted October 8, 2006 Share Posted October 8, 2006 Very nice, i was just wondering how you did the tabbard on your librarian :devil: Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1111569 Share on other sites More sharing options...
Luther - the fallen Posted October 9, 2006 Share Posted October 9, 2006 HOLY :lol: Scuzzy.. those are beautiful.. and easy.. Might nick the idea for my T. sons.. Luther... Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1112163 Share on other sites More sharing options...
NemFX Posted October 9, 2006 Share Posted October 9, 2006 That way is good for flowing ones, but a much easier and cheaper way is to cut a small rectangle-ish peice of pvc, paint it white or tan, draw a belt on it, and voila. Looks good too :P Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1112402 Share on other sites More sharing options...
Coop_DH Posted October 12, 2006 Share Posted October 12, 2006 Ok well i just finished a model with your tutorial and others from the DA web site. If i can get some good looking pics i think i can do you some good for it being my first time GSing....you gave good info.. Thanks Coop Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1113562 Share on other sites More sharing options...
Brother Lorien Posted May 6, 2007 Share Posted May 6, 2007 Just created a tabard aswell with the help of the tutorial... One downside though...nice and flowing on the front...but not on the back Is there a way to remedy this? Yes, but you get a pretty thick tabard that way :) Anyway i'm looking for a solution right now, if i find one...i'll post it here CJ Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1252569 Share on other sites More sharing options...
Skoby Posted October 6, 2008 Share Posted October 6, 2008 Looks good and I liked the pics in your other topic, what tools did you use? Is a GW sculpting tool and a knife good enough? Even just a sentence per pic would really help as some of the changes between pics are pretty subtle. Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1718530 Share on other sites More sharing options...
Thunder_god Posted October 9, 2008 Share Posted October 9, 2008 Nice pictures, but a few words to describe the actions would be nice too. Thank you for the pictures. Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1723498 Share on other sites More sharing options...
Evapilotone Posted October 9, 2008 Share Posted October 9, 2008 This is great. I'll be sure to try this. Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-1723548 Share on other sites More sharing options...
General Ravensong Posted October 29, 2009 Share Posted October 29, 2009 bookmarking this for when I finally get around to doing my deathwatch/sternguard. Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-2168905 Share on other sites More sharing options...
bloodseeker36 Posted June 30, 2010 Share Posted June 30, 2010 this Tutorial is amazing, I made like four of these tabards for my "command squad" in like 5 minutes...I found out though that if you flatten out the GS from the start the fold look quite nice in the end and once the tabard is placed on the model it can be readjusted to create a little fold that can be seen through the back. Truly great work...thanks Link to comment https://bolterandchainsword.com/topic/148061-modelling-tabards/#findComment-2450167 Share on other sites More sharing options...
