madscuzzy Posted October 15, 2008 Share Posted October 15, 2008 I start with a traditional marine JP. Now why do I do this and not with a normal back pack? Well, the normal backpack is small, so once the turbines are fitted in, the whole JP won't fit on the marine's back due to the shoulder pads. The traditional JP's base body offers more girth to fit the turbines in. http://scuzworks.com/SL40K/tutorials/Turbine%20JP/1.jpg I cut off both the vent intakes and nozzles off (I might use them later) http://scuzworks.com/SL40K/tutorials/Turbine%20JP/2.jpg http://scuzworks.com/SL40K/tutorials/Turbine%20JP/3.jpg http://scuzworks.com/SL40K/tutorials/Turbine%20JP/4.jpg I then fill in the hollow section with putty and let it harden, after which I smoothen and clean it up http://scuzworks.com/SL40K/tutorials/Turbine%20JP/5.jpg I stick washers down to simulate a connection point. I then drill through the washers. The ID of the washers are 3mm. http://scuzworks.com/SL40K/tutorials/Turbine%20JP/6.jpg http://scuzworks.com/SL40K/tutorials/Turbine%20JP/7.jpg Now onto the turbines! I start by getting 2 sizes of plastic rod. I use Evergreen Scale Models Stripstyrene sizes 232(3/8" or 9.5mm tube) and 234(7/16" or 11.1mm tube). These form the body and outer casing respectively. The body is cut down to 15mm(37/64") sections, and the casing is cut into 5mm(3/16") and 6.25mm(1/4") http://scuzworks.com/SL40K/tutorials/Turbine%20JP/8.jpg http://scuzworks.com/SL40K/tutorials/Turbine%20JP/9.jpg Once assembled, I drill a 3mm hole (and insert a 3mm diameter rod later) http://scuzworks.com/SL40K/tutorials/Turbine%20JP/10.jpg I glue the turbine fan from the droppod on the top, being sure to align it in the centre. http://scuzworks.com/SL40K/tutorials/Turbine%20JP/11.jpg http://scuzworks.com/SL40K/tutorials/Turbine%20JP/12.jpg Insert rod, nozzles and... http://scuzworks.com/SL40K/tutorials/Turbine%20JP/13.jpg The finished JP. Detail as required. :( The chopped off nozzles can be fitted into the turbines to act as as the nozzles if you wish. http://scuzworks.com/SL40K/tutorials/Turbine%20JP/14.jpg Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/ Share on other sites More sharing options...
Cpt Ultio Posted October 15, 2008 Share Posted October 15, 2008 That's for the intake, but what about the bottom of the turbine? Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-1733051 Share on other sites More sharing options...
madscuzzy Posted October 15, 2008 Author Share Posted October 15, 2008 Edited in the line: 'The chopped off nozzles can be fitted into the turbines to act as as the nozzles if you wish.' Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-1733061 Share on other sites More sharing options...
Cpt Ultio Posted October 15, 2008 Share Posted October 15, 2008 Ah, fair enough, would I be allowed to host this tutorial on my website? (Website is still in the WIP stages) Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-1733163 Share on other sites More sharing options...
wiplash Posted October 15, 2008 Share Posted October 15, 2008 could we have pics of the bottom of them, easier to understand with pics Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-1733294 Share on other sites More sharing options...
madscuzzy Posted October 15, 2008 Author Share Posted October 15, 2008 I don't have them installed yet as while I did plan to use them (and did an initial test fit_, I'm still debating on whether I want to build my own exhausts. I will update this again when I have fully finished it, but at present, I've only done this. I trust that the folks here should be able to continue from here if necessary for now. I would prefer to keep this here Cap...:P Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-1733343 Share on other sites More sharing options...
Cpt Ultio Posted October 15, 2008 Share Posted October 15, 2008 Fair enough, Just wanted to ask that's all you can do really. Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-1733365 Share on other sites More sharing options...
Dezzo Posted October 16, 2008 Share Posted October 16, 2008 *calls forgeworld and tells them to copy this idea* xD Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-1734503 Share on other sites More sharing options...
JMcL63 Posted June 30, 2009 Share Posted June 30, 2009 Lovely work madscuzzy, just lovely! I'm going to copy it, then I'm going to decide what to do with it! Oh, the B&C PC&A, a veritable cornucopia of delights. :D Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-2035717 Share on other sites More sharing options...
TheBobulator Posted July 1, 2009 Share Posted July 1, 2009 anything to replace the dp fans? Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-2036242 Share on other sites More sharing options...
Bannus Posted July 1, 2009 Share Posted July 1, 2009 Check here. Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-2036283 Share on other sites More sharing options...
Naysmith Posted July 3, 2009 Share Posted July 3, 2009 That looks just great! Thanks i might use it some day for Chaos Jumppacks. cya Link to comment https://bolterandchainsword.com/topic/149218-turbofan-jps/#findComment-2039222 Share on other sites More sharing options...
