dishchi Posted October 19, 2008 Share Posted October 19, 2008 http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0630.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0629.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0628.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0627.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0626.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0625.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0624.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0623.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0622.jpg http://i12.photobucket.com/albums/a247/dishchi/Warhammer%2040k/Nurgle%2040K/IMG_0621.jpg C&C wellcome... Link to comment https://bolterandchainsword.com/topic/149671-mark-i-nurgle-dedicated-bl-predator/ Share on other sites More sharing options...
HJL Posted October 19, 2008 Share Posted October 19, 2008 very nice use of old and new bits, im looking to start using magnets, can you show me where you put them on your tank? Link to comment https://bolterandchainsword.com/topic/149671-mark-i-nurgle-dedicated-bl-predator/#findComment-1738561 Share on other sites More sharing options...
dishchi Posted October 19, 2008 Author Share Posted October 19, 2008 the mags are holding the side sponsons and are not clearly visible on the pics... Link to comment https://bolterandchainsword.com/topic/149671-mark-i-nurgle-dedicated-bl-predator/#findComment-1738595 Share on other sites More sharing options...
ShinyRhino Posted October 20, 2008 Share Posted October 20, 2008 Very nice work. I like the little details, like the teeth knocked off the dozerblade. Looks like you biggified the old Rhino chassis by putting two layers of plastic between the track walls and the hull, and chopped the tracks from underneath and added plating under there, as well. I'm in the processof doing the same to a Razorback, but am trying to decide if I want to use the same methods you did, or not. I'm thinking I may just thicken with sprue between the hull and track walls, and plate over the gap for an "extra armor" effect. How fiddly did you find it to chop the wheels and tracks off the underside, and how well did they fit when you added them back on? Razor saw or knife for the cutting? Link to comment https://bolterandchainsword.com/topic/149671-mark-i-nurgle-dedicated-bl-predator/#findComment-1739548 Share on other sites More sharing options...
dishchi Posted October 20, 2008 Author Share Posted October 20, 2008 I used a hacksaw to remove the tracks, I treated them with a little sndpaper & glued 'em back, simple as ABC. Link to comment https://bolterandchainsword.com/topic/149671-mark-i-nurgle-dedicated-bl-predator/#findComment-1739868 Share on other sites More sharing options...
