Counter Attack rules clarification please
Kaine
I've read most of the old posts on this topic, but i'd like to make sure i understand it correctly.
If a Blood Claw charges, i get 1 attack base, 1 for extra CCW, and 2 for Berserk Charge.
If a Blood Claw is charged and passes the leadership test for counterattack they get 1 attack base, 1 for extra CCW and 2 for BC.
I assume they only get a total of +2, rather than +2 and the +1 for counterattack ? (i make this assumption because it says in Berserk charge that its +2 attack instead of +1, so i assume you dont get the +1 for counter ?).
Is this correct ?
(I dont want to start a debate on this one, that seems to have been done already)
counter attack doesnt grant +1 attack. What it does, is if you pass your Ld test, you count "as charging". Which means +2 attacks from BC's due to berzerk charge, +1 for any other models for just charging.
The only thing that grants +1 attack just for countercharging would be the wolf pelt, which is why it's essential for for WGPL's and IC's. Ragnar gets a nice +3 attacks on the counter, +1 for 2 CCW, and 4 base attacks for a whopping 8 attacks!
So, hang on. If a WGPL counters, he gets the special rule countering attack, assuming the leadership test is passed AND an attack for the wolf pelt? Or am I just being greedy? ;) Otherwise the wolf pelt seems useless, surely, since we get the attack anyway on proviso of a leadership pass.
Ah but they're very much into the spirit of the rules more than the letter of them. I do understand that to an extent. Someone should do a thread outlining the more important changes 5th has made on the wolves & what equipment is now useless etc.
