Shadow Dawn Posted November 25, 2008 Share Posted November 25, 2008 So just a quick one. Can you run or fleet from a Drop Pop. Link to comment https://bolterandchainsword.com/topic/153123-run-from-dp/ Share on other sites More sharing options...
King_Pash Posted November 25, 2008 Share Posted November 25, 2008 Yes, but you cannot charge the turn you DS. So if you have Shrike (as I suspect you do otherwise you wouldn't be asking this) then you can run and assault in any instance that it allows you to do it. It does not allow you to do this when you Drop Pod onto the battlefield. Link to comment https://bolterandchainsword.com/topic/153123-run-from-dp/#findComment-1784508 Share on other sites More sharing options...
AkiraCho Posted November 25, 2008 Share Posted November 25, 2008 nope. what he said but yeah haha i ment yes no charging Link to comment https://bolterandchainsword.com/topic/153123-run-from-dp/#findComment-1784509 Share on other sites More sharing options...
Shadow Dawn Posted November 27, 2008 Author Share Posted November 27, 2008 What about from deep strike...? Link to comment https://bolterandchainsword.com/topic/153123-run-from-dp/#findComment-1788280 Share on other sites More sharing options...
King_Pash Posted November 27, 2008 Share Posted November 27, 2008 No. It's under the same rules as Drop Pods since they Deep Strike onto the table. Link to comment https://bolterandchainsword.com/topic/153123-run-from-dp/#findComment-1788290 Share on other sites More sharing options...
SeattleDV8 Posted November 28, 2008 Share Posted November 28, 2008 You may run. You may not assault. Link to comment https://bolterandchainsword.com/topic/153123-run-from-dp/#findComment-1788479 Share on other sites More sharing options...
King_Pash Posted November 28, 2008 Share Posted November 28, 2008 You may run. You may not assault. Seconded. You can run as this forgoes your shooting phase (which you can do once you DP or DS) but you cannot charge. Even if you have fleet. The ONLY way you can do this that I can think of is to use Vanguard Vets' Heroic Intervention which allows them to charge from DS (but does not allow them to run or shoot). Link to comment https://bolterandchainsword.com/topic/153123-run-from-dp/#findComment-1788776 Share on other sites More sharing options...
Kapitan Montag Posted November 28, 2008 Share Posted November 28, 2008 The ONLY way you can do this that I can think of is to use Vanguard Vets' Heroic Intervention which allows them to charge from DS (but does not allow them to run or shoot). Yes, and just to clarify- Heroic Intervention only works when they deep strike with jump packs. So still no assault from drop pods. Link to comment https://bolterandchainsword.com/topic/153123-run-from-dp/#findComment-1789103 Share on other sites More sharing options...
