Do Ordnance Weapons...
Br.Pat
  • 2 months later...
Yep ordnance barrage can be fired just like regular barrage weapon and in that case ignores the minimum range listed. Also if you fire ordnance or ordnance barrage, you can't fire any other weapons period (not even defensive weapons).
If you fire it as a barrage weapon, you can't move, and if you fire at a target that is out of LOS it scatters the full 2D6 (BS doesn't reduce this if fired indirectly like that).
I sure you meant;
"Yep ordnance barrage can be fired just like a regular ordnance weapon". Right?
